20 Most Recent DFI 865PE INFINITY MOTHERBOARD P4/A&GB L&R/1394/ATX (MTH865PEI) Questions & Answers
Have you tried givemefile.net?
go to :
http://www.givemefile.net/search.html
copy the line below into the search line, and that should bring up all the drivers you need.
INFINITY MOTHERBOARD DFI 865PE
DFI 865PE... | Answered on Apr 27, 2009
http://www.gamesfree.me/games/tags/dfi/
DFI Computers &... | Answered on May 26, 2014
change power buton or reinstal windows.
DFI Computers &... | Answered on Feb 18, 2014
use norton
DFI Computers &... | Answered on Nov 11, 2013
That will be a very big blob of goo! Or a very large and wobbly hacker.
DFI Computers &... | Answered on Aug 05, 2013
http://www.pcmag.com/encyclopedia/term/38515/beep-codes
HERE ARE SAME READING TO HELP YOU TROUBLESHOOT THE PROBLEM.
DFI Computers &... | Answered on Aug 02, 2013
Hi steve, PC repair is trial & error. I suggest you replace the power supply or test the power supply in another PC that also uses 4 SATA drives & two PCI-E slots for starters. Two boards with the same problem is odd. You must have the CPU & fan connected, memory installed, ATA 24_pin main power plugg connected (Page 17 in manual). 4-pin_12v power connected which is located (Just to the left of DDR1 memory slot). Looking at you're board the power supply should be no less than 500w.
CPU must have thermal grease between CPU & heat sink.
Even though you have fans running & LED's on & flashing, the power supply seems to be the first item to check. Make sure the bottom of the motherboard is not touching the PC case.
Try the above & post you're finding here.
Good Luck!
Mike
DFI Computers &... | Answered on Jun 30, 2008
Google search "Download Canasis". You will get multiple links to use.
Computers &... | Answered 1 hour ago
Computers & Internet Logo
1 questions posted
Top DFI Computers & Internet Experts
Ekse
Thomas F. Schneider
Steve Frost
Steve Frost
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • DFI Computers & Internet
Most Popular Question
need drivers
  • Computers & Internet
