20 Most Recent Teac (CDW552GA02) (CDW552GA02/10PK) CD-RW/DVD-ROM (Combo) Burner Questions & Answers
2answers
Have a cd stuck in
Have you tried a smaller flat-head screwdriver or two to pry the door open. It won't hurt it.
9/9/2010 1:02:36 PM • Teac... • Answered on Sep 09, 2010
How can play the cd room with out the cpu
u cant
1/24/2010 7:31:07 AM • Teac... • Answered on Jan 24, 2010
2answers
Why display "disk full" or "Wrong disk" and the disk is new
Try to used Nero, application that will help your driver execute the appropriate task to execute.
Please rate me SOLVED
8/14/2008 12:13:57 AM • Teac... • Answered on Aug 14, 2008
Where do I hook up my Teac 1200 Reel to Reel to my Kenwood Kenwood VR309
This will all depend on the age of the equipment and what connectors are on each one. Could you post photos of the panels on them showing what connector ports are actually there. How old is the reel to reel? The really early 1970's models will probably not work or will need specialist cable adapters to get it to connect to the Kenwood and even then it may not work. The 80's and some of the 90's ones used Component, Phono or Jack Plug connectors. The really modern ones use Optical cables. In general it usually sets up by connecting to the "OUT" port on the reel to reel and the matching "IN" port on the Kenwood.
5/1/2023 7:51:37 PM • Teac Computers &... • Answered on May 01, 2023
Teac Micro-Hi-Fi CD-X8 replacement cable
11/17/2021 10:21:39 PM • Teac Computers &... • Answered on Nov 17, 2021
Hello. I have a TEAC rw-cd 22 that I have had good luck recording with. Recently, I sometimes get a no disc reading on the left tray when I am using it as the source to burn on the right tray. It reads on the right tray, so I know that it works, but the left tray no read screen means that I cannot use the left tray as a source for recording. Thanks.
There are several things that you can try. Move the carriage for the laser diode to the center area, Put a disk in and note where the label is and then eject it to see if it is spinning, check the voltage on the laser diode. This will give you an idea of what the issue is.
2/20/2021 4:33:39 PM • Teac Computers &... • Answered on Feb 20, 2021
My TEAC CD/RW 890 comes on and just says COM ERROR. It won't open or do anything else.
Hi Albert, for what you say, COM ERROR, corresponds to an internal communication problem, try disconnecting the TEAC, from the power outlet, wait a couple of minutes and reconnect it, the problem should be solved This is indicated on page 26 of the User Manual If not, you would have a more complicated problem and I suggest you consult a specialized technical service I hope you can solve the problem Greetings Franco Dosil Hola Albert, por lo que comentas, COM ERROR, corresponde a un problema de comunicacion interior, prueba desconectar el TEAC, del toma corriente, esperar un par de minutos y volver a conectarlo, deberia resolverse el problema Asi esta indicado en la pagina 26 del Manual de Usuario Si no es asi, ya tendrias un problema mas complicado y te sugiero consultar a un servicio tecnico especializado Espero puedas resolver el problema Saludos Franco Dosil https://www.teac-audio.eu/downloads/2/2/8/1/6/CD-RW890_EFS_.pdf
8/26/2019 2:37:45 AM • Teac Computers &... • Answered on Aug 26, 2019
Where do I find a Windows driver for a small 3.5" TEAC USB floppy drive?
What operating system are you using? NOTE: A usb floppy drive will not work when plugged into a USB 3.0 socket, you need to plug it into USB 2.0 if you have one.
8/17/2019 11:31:00 PM • Teac Computers &... • Answered on Aug 17, 2019
0answers
Teac les6572f3d wont recognise usb storage for upgrade can someone help please
your usb may be in the wrong format
11/7/2018 8:35:22 AM • Teac Computers &... • Answered on Nov 07, 2018
0answers
My Dell XPS M1530 has a slot loading TEAC DVD -RW
Looks to me like a hardware problem
5/10/2017 10:59:52 AM • Teac Computers &... • Answered on May 10, 2017
Teac (CDW552GA02) (CDW552GA02/10PK) CD-RW/DVD-ROM (Combo) Burner Logo
3 questions posted
Top Teac Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a Teac Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Teac Computers & Internet
Most Popular Question
display disk full or wrong disk disk
  • Computers & Internet
