20 Most Recent
Hi-Touch Imaging Hi Touch Imaging 87.pbe01.10b Media Kit A5rt 6x4 Hiti P510s 660pk Ink Feed System Questions & Answers
I have Hiti P510S photo printer which was working
Double check the ribbon chip and make sure contacts are clean. Also make sure it is for the 4x6 paper size. If it is a 5x7 ribbon it will not work. Have you printed 5x7's before? If so this is probably the issue.
Also check to make sure firmware is up to date. . I hope that helps!
RE: Vibe USB Turntable Model:
your choice of "Vibe" turntable could have not been worse.
Any serious Vinyl collector would not use such a cheap piece of equipment.
You Get What You Pay For is so very true in this case.
How to identify a genx scanner device for Windows 7
When you have no driver for this Windows version and the former did not work, even in compatibility mode, then try the free program IrfanView. In the File menu first go to Select scanner source. VueScan is also a program supporting many scanners but not free.
