20 Most Recent
Fujitsu Siemens Fujitsu LifeBook E8420 (FPCM72774) PC Notebook Questions & Answers
How do i make my bluetooth on
Check the drivers: Go to the control panel/devices. Look for the network adapters line. Right click on one or more lines and do an Update of Drivers.
Wifi & Bluetooth does'nt work anymore
Hi ,it sounds like you need to reinstall the drivers , what operating system do you have ,,,,,,,,let me know Roy
How to format a install windows xp3 on FUJITSU SIEMENS
backup your data first in any external source. insert bootable cd of xp and boot from it. follow the instruction and finish the installation after that install required drivers and apps.
in starting you need to select boot from cd., can be select-able from bios and also by pressing f12.
My power button is not working, is their any way to start the nootebook making a power shortcut?
If the laptop was opened up, (ALL power removed -> AC adapter and battery; PLUS -> anti-static precautions taken!), and the laptop has a power on switch, (under the power on button), that plugs into the motherboard; you can unplug the switch, and touch the motherboard contacts to try to turn the laptop on. (Sorry about the run-on sentence) Jump a wire or similar, across the contacts, and see if the laptop turns on. Could try to be more specific, and detailed, if you had listed more info about the Fujitsu Lifebook. Such as it's Series number and Model Number. Example: Fujitsu Lifebook E8210. In this example E is the Series number, and 8210 is the Model Number. Post back in a Comment.
Regards,
joecoolvette
How do I get into bios
As soon as the Fujitsu logo appears on the screen, press the F2 key. If this doesn't work, please post the specific family and model of your Fujitsu Siemens LifeBook PC.
Thanks,
Roger
How to download recovery disc
Recovery disc comes from the manufacturer and looks for the serial number of your computer. You would have to buy a recovery disc from the said manufacturer or just go buy a new operating system CD
Print screen button
GO TO CONTROL PANEL THEN FONT THEN TEX SERVISES AND INPUT LANG THEN CHOUSE WHAT YOU WONT
