20 Most Recent
Transcend 2.5 StoreJet Portable Shockproof with U.S. Military Standard -250GB Mobile - Re... USB 2.0 Hard Drive Questions & Answers
500 GB Transcend HD.
how long was it the water for was it fully submerged ?it might water damaged beyond repairleave it in a very warm to hot place for a few hrs to dry out any moisture inside it hope this helps
Transcend external harddisk 250gb not
Copy any data on the disk onto some other media using another computer (I know you have friends running XP and Vista) then just format the hard disk.= as requested by 7.
HOW MUCH
I suggest you Google search the Internet for this model Trancend. Then you can compare the prices from the various suppliers.
When I connect my storejet 25 mobile 250 GB it
When you power up the computer press F8 key then enter in safe mode note down the drive letter like f: then go to command prompt and type "chkdsk f:" without "" where F: assume as your drive letter. then follow below. First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
The 2 GB Store n
First thing to do is run check disk on the computer to be sure that file is not corrupt. The file name may be too long or not recognized.
5/5/2017 5:04:23 PM •
Transcend...
Answered
on May 05, 2017
Dropped my Transcend Storejet25p 5oo gb on floor !
Your hard drive is damaged beyond repair. When a hard disk makes a clicking sound and the computer does not detect it then the hard disk is faulty. This is commonly known as "The click of death". There is no way of fixing this hard drive, if you need to recover your data, then there are companies that can recover data off faulty hard drives BUT it will cost you an arm and a leg for their services.
3/2/2015 1:37:57 AM •
Transcend...
Answered
on Mar 02, 2015
How to prepare Transcend StoreJet 25M3 for use with Acronis True Image 2014 backup Software ?
The disk size of 698GB under Windows is correct for a 750GB drive.
This tells you there is only one partition on the Transcend drive.
It is best to reformat the Transcend drive to NTFS, unless you need to also read from the Transcend drive using a computer that does not support NTFS.
I would expect Acronis backup inviting you to reformat to NTFS if you would try using a FAT32 drive for backup. FAT32 has a file size limit of 4GB which may impede backups.
5/3/2014 4:41:19 PM •
Transcend...
Answered
on May 03, 2014
PC not detecting HD
HDD not Detecting only if you HDD data cable damage, HDD power Cable damage, HDD port damage, or HDD bad sector. But normally you change HDD data or power cable or mother board port. And i suggest mother board all connection disconnect and only HDD connect and open bios and search your HDD detected.
Thanks..
More Tech Support Contact
http://www.techsupportmart.co.uk/
2/6/2014 9:14:49 PM •
Transcend...
Answered
on Feb 06, 2014
