20 Most Recent
Quantaray QSR-9550 Tripod Questions & Answers
The plastic leg ht clamps
Well if you don't want to return it and it doesn't seem to you like an easy fix, by comparing how the mounting supports are connected on the legs, than you know you have a defective tripod?
There are multiple kinds of support clamps/brackets you can use or...
I would just go purchase a small roll of Automotive Velcro, (thats the toughest and trongest stuff around and cheap at Walmart), to mount to and strap around it, Or you could use a belt, string anything to wrap or tie around it!
Dollor General sells a small box of I believe (8) long strips of Velcro for $2.00 you can attach to some material, (stronger the better) on both ends and strap it cloed that way! That's also pretty good velcro, but really needs to be sewn or safety pinned to the material!
I really don't blame you, I hate having to return things, its a pain, that is for sure! Atleast you don't have the opposite effect of it closing on you! lol You'd have to take it back then!
Kind regards!
Martie
9/15/2011 6:13:00 PM •
Quantaray...
Answered
on Sep 15, 2011
One of the leg extension locking devices will not hold the leg down
Unfortunately, Quantaray is no longer in business, so there is no service department to go to in order to get something like that fixed. And replacements leg locks are not available. It sounds like you have a worn out screw or spring in your leg lock. You might be able to find a new tripod of a similar size and shape here if you can't find a replacement anywhere: www.itripod.comGive me a call if you have any questions.AmandaSpartan Photo Centerwww.tripodquickrelease.comwww.bogentripodparts.comwww.itripod.comwww.spartanphotocenter.com
12/12/2012 7:18:48 PM •
Quantaray...
Answered
on Dec 12, 2012
I have a QS-TM and
Tripod mounts are standard size for most cameras, there are strictly speaking 2 sizes but it is unusual to find a modern camera with the wrong size; it should screw directly into the camera (assuming you have a "standard" mounting plate with the tripod!) If it is too large/small you need an adapter, 3/8" to 1/4" or vice versa, but that would be unusual.
Most 35mm camera bodies accept a 1/4" diameter, 20 thread-count screw
1/11/2011 9:04:52 PM •
Quantaray...
Answered
on Jan 11, 2011
Film won't load on Vectis 300 MinoIta
The clue is in your descrition; Old.
If the mechanism has jammed, due to age or lack of use that causes tarnisg=hing on the contacts, the motor/mechanism will not load.
I would get it serviced at an aurgorised Minolta repair shop.
Contact Minolta for a list of authorised repairers.
3/22/2024 7:04:40 AM •
Photography
Answered
on Mar 22, 2024
I tried to use a 16GB PNYcard in my picture fram and it would not work. It said "No Card" on the screen. What's the answer?
If your picture frame is not recognizing the 16GB PNY card and displaying a "No Card" message, there could be several reasons for this issue:
- Compatibility: Some picture frames may have limitations on the size or type of memory card they can accept. Ensure that the picture frame is compatible with SDHC or SDXC cards, as these are the types commonly used for higher-capacity cards like 16GB.
- File System: Check if the memory card is formatted in a compatible file system such as FAT32 or exFAT. Some picture frames may not recognize cards formatted in other file systems. You may need to format the card using a compatible file system on your computer before using it in the picture frame.
- Card Reader Slot: Ensure that the memory card is inserted correctly into the card reader slot of the picture frame. Sometimes, improper insertion can prevent the device from detecting the card.
- Card Compatibility: While SDHC and SDXC cards are generally backward-compatible with devices that support SD cards, some older picture frames may have limited compatibility with higher-capacity SD cards. Try using a lower-capacity SD card (e.g., 2GB or 4GB) to see if the picture frame recognizes it.
- Faulty Card or Picture Frame: If none of the above solutions work, there may be an issue with either the memory card or the picture frame itself. Try using the memory card in a different device to check if it's functioning correctly. Similarly, try using a different memory card in the picture frame to see if it's able to recognize it. If the problem persists, there may be a hardware issue with either the card or the picture frame, and you may need to contact the manufacturer for assistance or consider replacing the faulty component.
By following these troubleshooting steps, you should be able to determine the cause of the issue and resolve it accordingly.
3/16/2024 9:30:07 AM •
Photography
Answered
on Mar 16, 2024
