20 Most Recent Toshiba Satellite L655-S5153 Laptop Questions & Answers
Usually you can use a flat screw driver under the side of the keyboard key. On older keyboards you could use a twin flex cable split in the middle and the hole pushed over the top of the key.
Then pull both ends and the flex slides under the key to give a better grip and pull upwards to remove the key.
Toshiba... | Answered on Jan 11, 2015
first, recover your files. You will need to use something like this data recovery program.
http://www.facebook.com/pages/Asoftech-Data-Recovery/290956907592436?sk=info
I've had to use it many times in the past but in this case you need to plug that drive into another system as an external drive or slave drive and run the software from there. It will rebuild the drive and hopefully recover the files.
After you get back your files, you can then format the drive and reinstall your system.
Toshiba... | Answered on Nov 15, 2012
Hi grlbaby4
Re-download you driver for the touch pad
Go to the following webpage and download the driver for your Toshiba touch pad
Please rate me
Bud
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=3253760&rpn=PSK1WU&modelFilter=L755-S5153&selCategory=2756709&selFamily=1073768663
Toshiba... | Answered on Oct 08, 2012
reinstall windows and added soddim-RAM
Toshiba... | Answered on Jul 27, 2011
If using windows go to start / control panel / sound............
Toshiba... | Answered on May 30, 2011
to get the driver for your Toshiba, follow the steps below:
go to http://support.toshiba.com/drivers
enter your laptop model ( Satellite L505) and download sound drivers and other necessary drivers needed for your laptop to operate well.
Good luck.
Toshiba... | Answered on Sep 12, 2019
uninstall the software and put it again
Toshiba... | Answered on Sep 06, 2019
All drivers are available free of charge from Toshiba's web site.
Toshiba... | Answered on Jul 23, 2019
toshiba satellite error 0xc000021a
Blue screen
Toshiba... | Answered on Jun 21, 2019
Do you have a wifi card in the computer? It is a hardware part that you need so that the computer can connect to the wifi. If you have that but can't find it in the operating system. I suggest that you either install or update the driver for it.
You can use RadarSync to scan your computer for the available updates of your wifi driver. Make sure that you connect to the internet first using your ethernet so that it will detect the available driver updates somewhere in the databases of the manufacturer.
David
http://goo.gl/CxsY9u
Toshiba... | Answered on May 22, 2019
go to your browser proxy setting and make the proxy automatic
Toshiba... | Answered on May 21, 2019
check the power ic of the laptop with laptop technicians
use VLC it plays everything it even has extensions like subtitle downloader. VideoLAN Official page for VLC media player the Open Source video framework
Toshiba... | Answered on Apr 29, 2019
Take another video and don't drop your gear. The mishap obviously ruined the original.
Toshiba... | Answered on Apr 02, 2019
Remove the battery and see if it starts up fine, if not then try the following:
1. Unplug your charger cord.
2. Remove the battery.
3. Press and hold the "Power" button for 30 seconds or longer
4. Now plug back in the power/charger cord.
5. Now put the battery back in.
6. See if it starts up now, laptops often get stuck in hibernate mode.
Toshiba... | Answered on Nov 13, 2018
Follow the procedure:
Device Manager
USB Root Hub (USB 3.0)
Change driver, manually, to "Generic SuperSpeed USB Hub"
Now the hardware is working
Upgrade the driver again, automatically
Toshiba... | Answered on Sep 25, 2018
Toshiba Satellite L655-S5153 Laptop Logo
Popular Tags
10 questions posted
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
loaded data from another
  • Computers & Internet
