Troubleshooting & Support
Hot Topics:
- rca rp4896a
- rp5430b clock...
- clock cd radio...
- rp4896a
- rca rp5430b
- setting clock...
- clock
- rca clock radio
- rp5430b
- user...
- 24 hour
- set alarm clock...
- SET TIME
- alarm
- rca rp5640
- awr1 1w remote
- setting time
- cd player...
- setting alarm
- cd player...
- static sound
- play cd
- antenna
- turn
- display work
- working cd
- battery remote
- Manual CD...
- awrcc1
- lcd working
- View All »
Problems & Solutions
I don't know to set the time and alarm. Cd...
You do not have to set the clock time as a built-in automatic time set system is equipped in this clock powered by 3V (2 x “AA” batteries...
How do you deactivate the alarm? I can turn it
Press the "wake cancel" button and then press the number of the alarm that was set (either button 1 or 2). The display will...
I have a rca clock
Hello To disable the wake up function completely; Press [Bell Symbol] [Music Symbol] & press '1' of '2' repeatedly unti...
today i woke up with my clock beside me and it was
There are two speakers. Disconnect the one at the bottom that looks like a coin with glue on it. As far as I know it does nothing because...
How to find and
You can get the manual on the link below. If you can not read it in the box with the % change it to 100%...
The buttons on my clock radio no longer
Got the same problem than you, those black button on back row can easily fall inside the unit. RCA customer support told me it was the...
I need an instruction manual for my RCA Clock
There are three buttons under the heading "Dual Wake", WK1, Cancel, WK2. The WK buttons refer to the two wake time settings you...
I need an instruction book for RCA RP5620A
http://www.retrevo.com/support/RCA-RP5620-Clock-Radios-manual/id/404bh751/t/2/
RP3721A How to turn off NAP button
I've seen some comments that you can't turn NAP off once it's set. You can turn off NAP by holding down the NAP button for a few...
I purchased an RCA RP 5430 clock radio new in the
Here the user guide: Manual : RP5430. Click the link above, you will need to use the zoom option on adobe acrobat, as the manual is printed...
Set the clock on my RP4801A clock/radio
Following are the instructions for the RP5610 which looks very similar to the 4801A (that I also have). The only difference in the...
RCA RP 3755 Clock radio: CD player will not spin
HelloCheck the voltage at the terminals of the sled motor. If it is found OK, replace the sled motor. Sled motor do spins the...
I purchased an RCA Radio/CD player, with the...
To use the worry-free backup battery, get a 9V battery. Then look for the battery compartment on the bottom of the unit. Press the tab with...
no the product number is rc140 radio-reveil am/fm
You can get the instruction from here: http://www.voxxsupport.com/images/User%20Manuals%20-%20FAQ%27s/RC140_OM.pdf I hope this is what you...
I need an operations manual
I have found an operating info for you here: http://voxrightnow.custhelp.com/app/answers/detail/a...
Unsolved Problems
What batteries will work in
What batteries will work in it? I've tried AA bateries (not the recharger ones) and it doesn't work at all...
the display for time has
the display for time has the bottom part greyed out, so that 12:00 pm looks like 17:00 pm with the last fragment of the...
I bought a used RCA
I bought a used RCA Model # RB3740C clock radio with cd player. I don't have a manual. Can you help?
cat pulled the plug.
cat pulled the plug. can't figure out how to reset time
Problem with the RCA RP3740
Problem with the RCA RP3740 Clock Radio Power went off and clock won't stop blinking
Re: RP3740 the time is
Re: RP3740 the time is off by about 15 minutes. I can't seem to figure out how to correct it. Manual is misplaced. Can...
My radio didn't change to
My radio didn't change to the daylight savings time no matter how many times I pushed the button. I tried changing...
I drop the clock radio about a foot from the
I drop the clock radio about a foot from the floor, now the screen is not showing the time. The dual alarm display is...
Upload a manual for RCA RP3740 Clock Radio
Specifications
TopKey Features
Full Product Name:RCA RP3740 Clock Radio
Tuner Type:Digital Tuner
Display:LCD
Music playback:CD
Snooze Alarm:Yes
Dual Alarm:Yes
Other Features
Presets:1 Presets
Warranty
Warranty:1 Year
What's your problem?
Fix-O-Meter
1,424
1,424 people have viewed this product
- 26 people asked about this product.
- 2 people found solutions for this product.
- 0 people have added this product. Be the first!
Manually...
