FixYa.com
RCA RCD150 Radio/Cassette/CD Boombox
All Products > RCA > Boomboxes
Problems with RCA RCD150 Radio/Cassette/CD Boombox?
Search inside RCA RCD150 Radio/Cassette/CD Boombox Knowledgebase
Troubleshooting and Support
Solved Problems for RCA RCD150 Radio/Cassette/CD Boombox RSS Feed Post a New Problem
Cassette player not working
Hi, The cassette player suddenly stopped working. The cassette doesnt run at all. I tried to use a cassette head...
1 Solution
car audio problem
2000 olds Intrigue rear speakers inop installed 2 difrent sterios same problem
1 Solution
subwoofer unit not powering on
i have a warfedale dvd60st subwoofer + amplifier built in. this means that i can physically unscrew the amp off the...
1 Solution
07 Armada
I have a 2007 Nissan Armada with the AM/FM/XM/ 6 CD changer and a video system all OEM. The display when using the XM...
4 Solutions
repair advice
Bush boom box 004 DAB Radio - how do you get into the casing for repair?
1 Solution
CD player/boombox
i can't locate the remote and I cannot get the disc tray open for loading.
1 Solution
Durabrand Model1085 CD Player w am/fm/...
cd will not play, the lens is broken. Can it be replaced and if so where would I find the right part
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for RCA RCD150 Radio/Cassette/CD Boombox RSS Feed Post a New Problem
RCD158D POWERING DOWN
MY RCD158D WILL PLAY FOR A MINUTE THEN POWER DOWN. IT WILL DO IT WITH BATTERIES ALSO. I CAN TURN IT BACK ON AND A FEW...
Post a Solution
Record on cassette player
I can't record on the cassette player. Do I have to have a microphone. After placing a cassette in player and pressing...
Post a Solution
CD Player
The player works about once a week, than quits. When a CD is put in, it takes a minute or so and then flashes...
Post a Solution
Boombox Wont Work
I was listening to a CD last night, it worked fine, but I went to use it today, and it wouldnt turn on at all. I tried...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Number of Discs1
FunctionsCD Player · Cassette Deck · Radio Tuner
Output Power5 Watt
CD Player
Playable Disk TypesCD-RW · CD-R · CD (Audio)
Playback ModesRepeat One · Repeat All · Random · Program
Tape Deck
Tape DeckSingle Cassette Deck
Tuner
Tuner TypeDigital Tuner
Tuner Presets20
Tuner BandsAM · FM
Amplifier / Speakers
Speaker Size4 in.
Amp & Speakers FeaturesBass Boost
ConnectionsHeadphones Out
EQ Presets4
Other Features
Included AccessoriesRemote Control
Voltage110 - 120 V AC
Batteries6 x D
Dimensions
Depth10.2 in.
Height6.8 in.
Width15 in.
Warranty
Warranty1 Year
RCA Contact Information
Main support number580-634-0151
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
