20 Most Recent Zodiac Desert Falcon watch #ZO4511 Watch for Women Questions & Answers
Yes, this is an indication that the battery is low.
No, the watch does not need any special pressure testing when the battery is replaced.
Any fine quality jewellery store will have the tools necessary to unscrew the case and access the battery. Just look for any shop that sells and services Rolex or Tag Heuer or any other similar quality dive watches.
The whole job should not cost you more than $15 parts included.
Good luck.
Zodiac Desert... | Answered on May 10, 2011
The problem could be that the watch is defective.
Zodiac Watches | Answered on Feb 23, 2018
need more to help you put a photo on so i can help you
Zodiac Watches | Answered on Nov 23, 2016
  • Remove back
  • Locate battery. Note mounting arrangement for later battery replacement
  • Obtain replacement battery
  • Install battery
  • Check operation
  • Install back
  • Set time, etc.
Zodiac Watches | Answered on Oct 20, 2016
look at the stem , there might be a small plastic stop there that need removed then push in slightly on the stem
Zodiac Watches | Answered on Oct 30, 2015
If the watch parts are out of production (Generally speaking manufacturers only keep enough parts to make repairs for about 5 years) a revision is another way of saying the workings of the watch will be replaced but not with the same parts it came with. This is usually a modification to accommodate a new movement.
Zodiac Watches | Answered on Sep 17, 2009
I have a pendulum wall clock from the president collection. If yours is the same or similar, the following may help:
*Look at the back for a slide switch labled "start" at the top and "set" at the bottom and move it to "set"
*Look for for small push buttons. They represent the hours and minutes. Push each in turn, the number of pushes to represent the time, ie, for 09:45, ignore the first(0), push the second 9 times(9)-push the third 4 times(4)- push the 4th 5 times(5). When done, push the slide switch back to "start".
If yours is the same as mine - a wall hung pendulum clock with Westminster chimes, made around 1988. I would be happy to scan and send a copy of the instructions.
John
Watches | Answered 24 hours ago
Zodiac Desert Falcon watch #ZO4511 Watch for Women Logo
1 questions posted
Top Zodiac Watches Experts
Ansel Alberto
Ansel Alberto
ray gallant
Are you a Zodiac Watch Expert? Answer questions, earn points and help others
View Most Popular
Zodiac Watches
  • Zodiac Watches
Most Popular Question
model zo 4509 desert falcon
  • Watches
