20 Most Recent
Samsung Earfitter Handsfree For SGH-s105, v205, v206, x430 Headset Questions & Answers
How can i sent a picture via computer to ceelphone
send a picture from that phone to your email, then simply email the pic back to the address it came from.
The address should be the "telephone#"@mms."serviceprovider".net or a variation thereof.
GOOD LUCK AND PLS RATE THIS POST!!!!! :D
6/8/2010 5:18:04 PM •
Samsung...
Answered
on Jun 08, 2010
MY LG TONE HBS-730 stuck on incorrect pin
i have samsung mobile
Here are some steps you can try:
Reset the Headset:
Turn off the headset.
Press and hold the REW (rewind) button and the PLAY/PAUSE/STOP button simultaneously for about 5 seconds until the LED indicator flashes purple.
The headset will reset, and you can try pairing it again.
Pairing with Samsung Mobile:
Make sure your Samsung mobile's Bluetooth is turned on.
Slide the power switch on the LG HBS-730 to the "ON" position.
The LED indicator on the headset will be solid blue, indicating it's in pairing mode.
On your Samsung mobile, go to the Bluetooth settings and search for new devices.
Select "LG HBS-730" from the list of devices.
If prompted for a passcode, enter "0000" (four zeros).
Once paired, you'll hear "Your headset paired."
Check Battery Level:
Press and hold the VOLUME DOWN button for 1 second to check the battery status. The audible alert will indicate the battery level (high, medium, or low).
Charge the Headset:
Connect the charger to the headset. While charging, the LED indicator will show a solid red light.
When charging is complete, the LED indicator will turn off.
Remember that the headset will automatically turn off if not paired within 3 minutes.
If these steps don't resolve the issue, refer to the HBS-730 User Manual for more detailed instructions.
Connect sony dr-tn200 bluetooth headset to samsung mx-h620 hifi
Bluetooth is a short-range (33 feet/10 meters) wireless technology that allows two Bluetooth-enabled devices to connect wirelessly and communicate between them. If your son's Samsung MX-H620 HIFI is not Bluetooth-enabled, the two devices will not be able to connect in any way. If the headset were corded (it is not because it is Bluetooth) you could plug its cord into the headphone (LINE/AUX IN) jack on the Samsung. if the Samsung system is not Bluetooth, the only option is to find a suitable Bluetooth adapter to make it Bluetooth-enabled. However, you can use the Sony headset to listen to music or make phone calls from Bluetooth-enabled devices that you own such as phone, tablet, iPod, iPad.
