20 Most Recent
Samsung ES30 Digital Camera Questions & Answers
The zoom did not operate
The solution is very simple.
you are going to remove the battery (while this screen is on) as the command screen tells.
And your camera should function properly.
I tried it and it worked.
NB; Do not try to close your camera then remove the battery.
Remove it while the camera is still on.
How do i delete pictures from a samsung ES30
To delete pictures, follow these steps:
To delete single file,
1. In playback mode (while viewing you pictures or videos), select a file and press the {Fn} key
2. Select YES to delete the file
To delete Multiple files,
1. In playback mode, press {Fn}
2. Select Multiple Delete.
3. Select the files you want to delete and press {OK}
Press {OK} again to cancel your selection
4. Press {Fn}
5. Select YES
To delete all files,
1. In playback mode, press {MENU}
2. Select File Options > Delete> All > Yes
How to transfer photos from the computer to camera
Depends on the type of computer you have.
If your computer has a slot to introduce a memory card, go to start, then computer and bring up the folder where
the desired photos you want to transfer are.
Copy the pictures.
At the "computer window," the memory card should appear.
Right click on it and choose paste.
I you meant to say HOW TO TRANSFER PHOTOS FROM THE CAMERA TO THE COMPUTER, insert the memory card into the computer; the computer should do it automatically, just follow instructions and choose a folder.
If the computer does not allow you to choose a folder, copy the memory card pictures and open a folder where you want to transfer the pictures, right click on the folder and choose paste.
I hope this info will help you.
Also, most newer cameras come with a USB cable, if you have it,
connect the cable to the camera and then the computer.
the pictures.
Factory reset
In camera settings menu, on the bottom of the screen you find Settings. In Settings is the only reset the camera knows. You only will reset the menus and shooting options. Date, time, language and video output settings are not reset.
If your camera has serious trouble, accessing menus or something like that, there is nothing like pressing a button for several seconds and everything will be ok. (not in the manual)
