20 Most Recent Sitecom xDSL/Cable Broadband Router DC-200 Questions & Answers
0answers
I have a new Sitecom 341 wireless N router setup
Theres a few things to try here 1) the acer may not like the type of wireless security you are using , WPA needs to have the correct hardware to work - log into the router and remove the wireless security and see if it will now connect - if it does, try putting the security back on and see if now connects - if not, you may need to change the security to WEP or use MAC Filtering 2) It may be that a firewall is blocking access to your network - try disabling the firewall 3) You may need to remove the wireless profiles on the PC and then reconnect and re-enter the security password - read here on how to do that http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm
3/23/2010 8:01:00 PM • Sitecom... • Answered on Mar 23, 2010
Suddenly no connection to the internet via wirelss. LAN via the same router works fine.
its the problem of your service provider.... contact your service provider
5/23/2009 10:34:32 AM • Sitecom... • Answered on May 23, 2009
Wireless router 300M no acces to the internet
You need first to configure the router to work with your modem, if you have the setup CD of the router just that one and then follow all the steps on the setup CD after you're done running the setup CD of the router power down modem and router for 1 minute then plug the modem first wait for about 30 seconds and then plug the router back , after that check if internet is already working........
11/7/2008 6:15:01 PM • Sitecom... • Answered on Nov 07, 2008
Playstation Party error
Try opening ports for the game on the router. This could be a firewall problem. Contact your game provider for the ports needed on your router
4/30/2008 3:08:01 PM • Sitecom... • Answered on Apr 30, 2008
3answers
Hi my girl bought a
Although this camera is not compatible with Windows 7, I suggest to try this download link also (extract the zip file and run the setup file). In case of no luck again, before running the setup file, right click on it, go to properties and at the compatibility tab check the box for windows XP sp3 compatibility and hit apply - ok. Run the setup file as usual.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
4/2/2020 2:18:26 PM • Sitecom... • Answered on Apr 02, 2020
My Sitecom wireless router has
try removing power to the wireless router and then put power back on.
2/1/2018 7:44:23 AM • Sitecom... • Answered on Feb 01, 2018
I have new router how to set password?
You need to login to the user interface of your router usually it's 192.168.1.1 or 192.168.0.1 or 192.168.2.1 or 10.0.0.1 you need to hard wire a computer to your new router first open a browser and type one of the ip address on the top, type it on the address bar of your browser enter the admin pw, you did not specify the brand of the router but most router admin username and password is admin / password or just admin without pw or just admin for the pw, once you are logged in look for the network settings there and you can edit or set pw for your network depending on the nerwork type, hope this helps
1/26/2015 3:59:00 PM • Sitecom... • Answered on Jan 26, 2015
Find network security key or password
Your security key by default is usually a number on the wireless router. Your router manual should tell you what the default is or where to find it. If you set it and forgot it, try to reset the router to default.
11/13/2013 8:56:31 PM • Sitecom... • Answered on Nov 13, 2013
Not able to configure router
If you post the Make, Model of Wireless device, the Computer Make, Model and the OS you are using,and a bit more info, perhaps we could help.
3/20/2013 1:28:03 PM • Sitecom... • Answered on Mar 20, 2013
0answers
Sitecom xDSL/Cable Broadband Router DC-200 Logo
12 questions posted
Top Sitecom Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Sitecom Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Sitecom Computers & Internet
Most Popular Question
new sitecom 341 wireless n router setup
  • Computers & Internet
