20 Most Recent
Audiovox ADV12 Portable DVD Player Questions & Answers
No picture or sound
Power button or screen turn on , but wow button lights up . Does take cds dwn but wont play them , says no disc
Dvd won't play
lens could be the last option to check, most common problem with portables is, the drive motor, try to change it then play it, still problem continues, then change the lens, it should solve your problem
Remote won't work
I got the ADV, but I don't have the remote control, does anyone know about compatible remote control list, or universal code for that one ? I'm in Barzil - S?o Paulo, If there is some autorizd store, please let me know about it.!
[email protected]
Best Wishes,
Luiz Antonio,
I HAD MY ADV12 IN
Hi, I am sorry to hear regarding your problem. These are electronic items and once repaired, would ask for maintenance from time to time. In market, as of now, the above model is available for around 120 bucks. If you repair, would cost you around the same or more than that if that might have been a some more issue other than Power Button. Better to buy a new one. I know it's hard, But that's the wise option. Any further help, let me know. Hope i helped you. Thanks for using ' Fixya ' and have a nice day!!
Disc won't load
I made the same mistake and settled for the cheaper solution. Had nothing but problems with it check out:
www.invisionindustries.com
Purchased the SL 7 for my wife’s Ford Edge and the Invision system is worth every penny!
Best of luck.
My adv12 doesn't have a picture when i'm playing a dvd.
This unit is having a problem with component failure, That is causing it to go into the protection mode.This could be a simple problem of bad capacitors in the power supply or a more serious failure of the semiconductor components. The unit should be taken or sent to a service center for repair. The Audiovox customer support website is www.audiovoxusa.com. Go to the customer support and fill out the form for service. I hope this information helps you with your problem.
Blue light on antenna isn't turning on remote start won't work.
It's possible that the issue with your Audiovox pursuit PRO9056c remote start system is related to the antenna or its connection. Here are a few things you can try to troubleshoot the issue:
- Check the antenna connection: Make sure the antenna is properly connected to the control module of the remote start system. You may need to remove the panel where the antenna is mounted to access the wiring and connections. Check the wiring for any signs of damage or corrosion, and make sure the connections are tight.
- Check the fuse: The remote start system may have a fuse that is responsible for powering the antenna. Check the fuse to make sure it is not blown or damaged.
- Reset the system: Try resetting the remote start system by disconnecting the battery for a few minutes, then reconnecting it. This may help reset the system and resolve any issues that were causing it to malfunction.
- Consult a professional: If you are not familiar with automotive electronics or are unable to resolve the issue with the above steps, it may be best to consult with a professional technician who can diagnose and repair the system for you.
It's also possible that there is a problem with the remote start system itself, such as a malfunctioning control module
2/16/2023 10:58:50 PM •
Audiovox...
Answered
on Feb 16, 2023
I have a Audiovox d1988 and the screen won't play. I have sound but no picture. Help!!!
Jim,
First thing I would do is try a different DVD to see if the problem persists. Otherwise, this device is equipped with integrated speakers, meaning it is unlikely that you will be able to replace them. You may be in the market for a new Audiovox, unfortunately; but before you scrap it I suggest taking it to a local electronic repair store near you.
Hope this helps,
Best regards
3/8/2019 11:36:14 PM •
Audiovox...
Answered
on Mar 08, 2019
