Audiovox FP1500 15 in. LCD Television
Problems with Audiovox FP1500 15 in. LCD Television?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Audiovox FP1500 15 in. LCD Television RSS Feed
View More Results for Audiovox FP1500 15 in. LCD Television
Questions and Unsolved Support Problems
Unsolved Problems for Audiovox FP1500 15 in. LCD Television RSS Feed
Answer
board 02370500 #mit t2l2-0 melted. where can i get another board
Answer
I have an Audiovox LCD FP1500 and i lost the remote. i was wondering if there were a way to set up... (More)
Answer
I lost our remote and cannot manually get to channel 3 with the channel selector on top of the TV
Answer
I have two vertical lines one blue and one red. The blue is to the left of the red and they are both... (More)
Find a Manual
Audiovox FP1500 15 in. LCD Television Manuals & Guides
Tips & Tricks
(Post a New Tip)
Lamp vs Ballast
This is to help explain the short lives of Lamps. WARRANTY: If a lamp fails within the first year replace Lamp and Ballast. If Lamp explodes do not... written by BIG IRISH
Polaroid flm-373b lcd tv black screen control box no power fix
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked.... written by stiv0
Enter expert mode on LG TV
For the 44" LG DLP model RU44SZ63D...press and hold the menu button the remote control until a four digit password is requested on the screen.... written by mlapres
Tv troubles
the newer tv are just computors in disguyes.they often won't come after a power surge and have to be reset,you must unpluge from the wall and wait 10... written by bsddog87
Falt Panel Screen Cleaning
If you are trying to clean a LCD or Plasma screen, use only recommended screen cleaners. Be very careful not to rub too hard or contrast coating may... written by edcor
TV has snowy picture or displays unusable signal, no signal or no sync.
What to do if you have an all snowy picture, blue screen or the TV displays unusable signal, no signal or no sync. When using a Satellite receiver or... written by johnnydiode
how to test flyback without taking it out of the board
a) basically it has to be acted upon by a supply voltage of at least 95V to work. b) of course, assuming the horizontal deflection oscillator works,... written by palaboy
LCD Flat Screen Common Problems
Have you ever wanted to know what causes a nice LCD to give out so soon? Poor electronics components such as Capacitors. I will tell you how to spot a... written by rulds2008
WikiManual
(Post a New Chapter)
How to Mount a Plasma TV on a Wall
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's... by wikihow
How to Connect a TV to a DVD Player Without A/V Jacks
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Audiovox FP1500 15 in. LCD Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Featured Listing
Ratings for the Audiovox FP1500 15 in. LCD Television
0
Owners Recommend
out of 1
Reliability
Ease of use
Value for Money
Rate and Review the Audiovox FP1500 15 in. LCD Television
Write a review:
Rate this product:
Would you recommend the FP1500 15 in. LCD Television to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for Audiovox FP1500 15 in. LCD Television
Key Features
Screen Size
15 Inch
Flat Panel Type
LCD
Display Resolution
1024 x 768 pixels
Display Capabilities
Aspect Ratio
4:3
Image Quality
Contrast Ratio
500:1
Pixel Pitch
.3 mm
Brightness
350 cd/m²
Output Color
16.7 million colors
Viewing Angle
130
Audio Features
Audio Type
Stereo
Secondary Audio Programming (SAP)
With SAP
Audio Leveler
Without Audio Leveler
Technical Features
Picture in Picture
Without PIP
Connectors
Headphone Jack
With Headphone Jack
Dimensions
Depth
2.67 in.
Height
13.54 in.
Width
19.13 in.
Weight
11 lb.
Warranty
Overall Warranty
90 Days
Audiovox Contact Information
Main support number1-800-229-1235, 1-800-645-4994
Support FAX1-631-233-3431
Describe your problem:
Top Flat Panel... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
