Audiovox FP1520 15 in. LCD Television
Problems with Audiovox FP1520 15 in. LCD Television?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Audiovox FP1520 15 in. LCD Television RSS Feed
View More Results for Audiovox FP1520 15 in. LCD Television
Questions and Unsolved Support Problems
Unsolved Problems for Audiovox FP1520 15 in. LCD Television RSS Feed
Answer
I need to use an universal remote on the fp1520 but don't have the codes. Thanks, sl
Answer
I need a driver for that works with Vista in order to use my FP1520 as a monitor.
Answer
My Audiovox FP1520 remote has died. Is there a universal remote that will work? I have tries GE with... (More)
Answer
is the model fp1520 digital ready or do we need a converter box
Answer
remote doesnt work for audiovox fp1520, universal doesnt work for this model, cant find anew remote
Find a Manual
Audiovox FP1520 15 in. LCD Television Manuals & Guides
Tips & Tricks
(Post a New Tip)
Polaroid flm-373b lcd tv black screen control box no power fix
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked.... written by stiv0
Plasma TV no pictures
If you hear a relay clicking all the time when you turn your plasma TV on is often just a few capacitor and resistor to replace. Cheap and every body... written by wings_it
tv in
always check the cables that are feeding the tv written by crcelect
Lamp vs Ballast
This is to help explain the short lives of Lamps. WARRANTY: If a lamp fails within the first year replace Lamp and Ballast. If Lamp explodes do not... written by BIG IRISH
Enter expert mode on LG TV
For the 44" LG DLP model RU44SZ63D...press and hold the menu button the remote control until a four digit password is requested on the screen.... written by mlapres
Tv troubles
the newer tv are just computors in disguyes.they often won't come after a power surge and have to be reset,you must unpluge from the wall and wait 10... written by bsddog87
Falt Panel Screen Cleaning
If you are trying to clean a LCD or Plasma screen, use only recommended screen cleaners. Be very careful not to rub too hard or contrast coating may... written by edcor
TV has snowy picture or displays unusable signal, no signal or no sync.
What to do if you have an all snowy picture, blue screen or the TV displays unusable signal, no signal or no sync. When using a Satellite receiver or... written by johnnydiode
WikiManual
(Post a New Chapter)
How to Mount a Plasma TV on a Wall
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's... by wikihow
How to Connect a TV to a DVD Player Without A/V Jacks
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Audiovox FP1520 15 in. LCD Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Ratings for the Audiovox FP1520 15 in. LCD Television
Owners Recommend
out of 1
Reliability
Ease of use
Value for Money
Rate and Review the Audiovox FP1520 15 in. LCD Television
Write a review:
Rate this product:
Would you recommend the FP1520 15 in. LCD Television to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for Audiovox FP1520 15 in. LCD Television
Key Features
Screen Size
15 Inch
Flat Panel Type
LCD
Display Resolution
1024 x 768 pixels
Display Capabilities
Aspect Ratio
4:3
Image Quality
Contrast Ratio
500:1
Brightness
450 cd/m²
Technical Features
Picture in Picture
With PIP
Sleep Timer
With Sleep Timer
Connectors
Headphone Jack
With Headphone Jack
Screen Text
Closed Caption on Mute
With Closed Caption On Mute
Dimensions
Depth
7.1 in.
Height
14.1 in.
Width
20.1 in.
Weight
11.5 lb.
Audiovox Contact Information
Main support number1-800-229-1235, 1-800-645-4994
Support FAX1-631-233-3431
Describe your problem:
Top Flat Panel... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
