20 Most Recent
LG 42LG7000 42 in. HDTV LCD TV Questions & Answers
42LG7000 not tuning
is your tuner set to scan for cable channels or tv channels. there is a difference though the cable input and the tv input use the same connector
How to get MPEG4 on 42lg7000
Purchased music files(*.MP3) may contain copyright restrictions. Playback of these files may not be supportedby this model.Music file on your USB device can be played by this unit.The On Screen Display may be different from your TV. images are an example to assist with the TV operation.MUSIC (*.MP3) supporting file.Bit rate 32 to 320Sampling rate MPEG1 layer 3: 32 kHz, 44.1 kHz, 48 kHz.
I have a LG dvd
player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning.
Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem.
Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates.
Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV.
The hum is simply the player trying to read the disc. It can't so, it spits it out.
Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
