FixYa.com
Garmin GPSMAP 180 GPS Receiver
All Products > Garmin > GPS Devices
Problems with Garmin GPSMAP 180 GPS Receiver?
Troubleshooting and Support
Solved Problems for Garmin GPSMAP 180 GPS Receiver RSS Feed Post a New Problem
DGPS antenna grounding
Again, thanks for all of the help on my DGPS problem. Some people have recommended that I run my differential and GPS...
5 Solutions
bluetooth enabling
whenever i try to enable the bluetooth to use the handsfree on the nuvi it freezes on the screen 'bluetooth...
1 Solution
I want to make a cursor (a 20 x 20 Pixel...
I want to make a cursor (a 20 x 20 Pixel Icon) flash about once per second on the map. In terms of GPSTOOLS resources.....
1 Solution
spell state on GArmin Nuvi 350
when Asked In what state is this address, i touch spell state, as soon as I type in the first letter, (P for...
1 Solution
uniden hand held scanner
I own a uniden 50 channel programmable scanner. I do not believe i am picking up all the channels i have programmed into...
1 Solution
Lost User Manual
How do you assign a telephone number a one-touch code?  I have misplaced my user manual.  This question is for...
Post a Solution
Garmin Forerunner 201 -- How to Open the...
How do you open the case on a Garmin Forerunner 201? There are no visible screws and trying to pry the two halves of the...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Garmin GPSMAP 180 GPS Receiver RSS Feed Post a New Problem
GPSMAP 180 power/data connector
which pin is which on the power and data connector on the Garmin GPSMAP 180?
Post a Solution
Garmin gps180 satellite search.
Hi everyone, I bought a boat and the gps180 was in it. When I turn it on, it searches for a satellite and never finds...
Post a Solution
garmin 180
When I turn on the GPSMAP 180 I get a message lost of back up memory. I replaced the battery and the unit worked fine...
Post a Solution
GPSMAP 180 Turns Off immediately after...
GPSMAP 180 Turns Off immediately after turning it ON. I tried to reset it by pressing QUIT+POWER, but it will not do the...
Post a Solution
Will not turn on
When holding the power button, to turn on the device, the screen pixelates dark and then goes blank. If I continue to...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
DesignationMarine
Receiver typeParallel-Channel (12)
GPS System
Waypoints250
Max. Horizontal accuracy< 3 feet
Garmin Contact Information
Main support number1-800-800-1020
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
