FixYa.com
Garmin GPSMAP 188C GPS Receiver
All Products > Garmin > GPS Devices
Problems with Garmin GPSMAP 188C GPS Receiver?
Search inside Garmin GPSMAP 188C GPS Receiver Knowledgebase
Troubleshooting and Support
Solved Problems for Garmin GPSMAP 188C GPS Receiver RSS Feed Post a New Problem
I was working with the maplibApi and found...
I was working with the maplibApi and found that it would crash the VB6 IDE.I tried the example called MapLibApi that...
1 Solution
Nokia 95
HOW DO YOU SWITCH IT ON! Feel stupid but doesn't seem to be working Many thanks
1 Solution
Garmin Streetpilot 7500 screen goes dead
After powering up, screen comes on, after 30 - 60 seconds of use screen goes black, like not power. Can be started...
4 Solutions
Kenwood KNA DV3200
12/10/2007 approx 3.30 I have a 2006 Bmw 3 series coupe. System - Kenwood Kvt 627, with KNA DV 3200 with KNA TM320...
1 Solution
Downloading North American Maps
Good Morning, I've purchased the North American Maps for my Garmin Nuvi 360. Now I'm trying to download them onto my...
1 Solution
garmin nuvi 200 route calculation problem
I cannot calculate the route properly it takes me to wrong destination and at any time shouts destination arrived
1 Solution
Destinator is not a valid Windows CE...
gps will not load said destinator.exe "destinator is not a valid windows CE application unit freezes up will not...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Garmin GPSMAP 188C GPS Receiver RSS Feed Post a New Problem
Aquiring Sat. Signal
Have GPSMap 188C GPS turns on and seems to get a signal...has time, date, depth but on top is says it is aquiring sat....
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Form FactorFixed
DesignationMarine
Receiver typeParallel-Channel (12)
Enhanced accuracyWAAS enabled
Display
Display Type16 Color LCD TFT Display
Display Size5 in.
Resolutions234 X 320
Technical Features
Special FeaturesWaypoint Icons,
Trip calculatorMaximum speed, Current speed
Marine FeaturesFish Finder
GridsLat/Lon, User Grid, UTM, Loran TD position format
Other Features
PC InterfaceSerial RS-232
Enviromental protectionIPX7 Waterproof Standard, High Impact plastic alloy case
GPS System
Update rate1 per second, continuous
Waypoints3000
Accuisition time - cold45 sec
Accuisition time - warm15 sec
Max. Horizontal accuracy< 9.82 feet
Enhanced position accurancy< 10 feet
Number of routes50
Warranty
Warranty1 Year
Dimensions
Depth2.6 in.
Height6.2 in.
Width6.3 in.
Weight1.7 lb.
Garmin Contact Information
Main support number1-800-800-1020
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
