FixYa.com
Garmin GPSMAP 276C GPS Receiver
All Products > Garmin > GPS Devices
Problems with Garmin GPSMAP 276C GPS Receiver?
Troubleshooting and Support
Solved Problems for Garmin GPSMAP 276C GPS Receiver RSS Feed Post a New Problem
Garmin GPS problem
Cannot Aquire satellites
2 Solutions
no satillite reception
My GPS is no longer able to determine my position. The unit goes into auto locate mode but no satillietes are deteced. I...
2 Solutions
Battery 276C
My GPS started to act up. It was charging fine and all of a sudden one day it stopped. The message I am getting is that...
2 Solutions
gps 276C doesn't charge fully
My 276C never indicates a full charge, either on mains or battery. It is 4 months old. I have completely discharged and...
1 Solution
GPS wont boot up
I bought a new Garmin GPSMAP 178C Sounder back in 2005.I finaly got around to change out my older GPS and Fishfinder....
2 Solutions
276C Memory Battery
My 276C has begun to malfunction. If it is switched off for more than a short period the clock loses time and it forgets...
2 Solutions
Downloading mapsets
I have different mapsets for my 276c garmin. Each time i select mapsets from mapsource to download it erases the...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Garmin GPSMAP 276C GPS Receiver RSS Feed Post a New Problem
garmin GPsmap276c won't go to any screens...
When I turn it on it won't go to any other screens and won't turn off without removing the power supply. ** buttons work...
Post a Solution
BATTERY CHARGING FAILURE
hi despite of having a brand new battery,i still have missing battery on the screen,and my devise is only working with...
Post a Solution
Map do not want to scroll
My 276c do not wan to scroll the map even though the pointer turns and shows the right direction . If you go to the...
Post a Solution
missing fitting instructions
hi can you help me i have just bought a boat which is fitted with a garmin gpsmap 276c but it isnt wired up and havnt...
Post a Solution
fitting ininstructions
hi ther i have just bought a boat which has a garmin gpsmap 276c with it however it is not wired up and i do not have...
Post a Solution
gpsmap 276c memory card
i have a 32mg memory card its empty , but when i try to transfer data with mapsource the gps show (transfer data) but...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Form FactorFixed
DesignationAutomobile
Map capabilitiesInternal, Map cartridges / Data cards
User interfaceKeypad
Receiver typeParallel-Channel (12)
Enhanced accuracyWAAS enabled
Display
Display Type256 Color LCD TFT Display
Display Size3.8 in.
Resolutions480 x 320
Technical Features
Audible FeaturesProximity Alarm, Anchor Alarm, Arrival Alarm, Off-Course Alarm, Clock Alarm
Included Software/MapsNorth America Maps, Canada Maps, Europe Maps
Marine FeaturesChartPlotter
GridsLat/Lon, MGRS, User Grid, UTM, Loran TD position format, Maidenhead
Other Features
PC InterfaceUSB
AntennaQuadrifilar Helix
Enviromental protectionIPX7 Waterproof Standard
GPS System
Update rate1 per second, continuous
Waypoints3000
Accuisition time - cold45 sec
Accuisition time - warm15 sec
Differential standardsDGPS Ready
Max. Horizontal accuracy< 49 feet
Enhanced position accurancy< 10 feet
Number of routes50
Battery
Battery LifeUp to 15 Hours
Battery Type and QuantityProprietary Lithium
Warranty
Warranty1 Year
Dimensions
Depth1.9 in.
Height3.2 in.
Width5.7 in.
Weight.85 lb.
Garmin Contact Information
Main support number1-800-800-1020
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
