Do they make DVD players that will play scenes from 5 DVDs in a random order? I know they make CD...
(More)
Do they make DVD players that will play scenes from 5 DVDs in a random order? I know they make CD players like that: I, however, amd looking for a DVD player that will play scenes from up to five DVDs in random order.
My daughter tried to turn on the dvd player by GE model #DGE505N. The dvd player worked perfectly...
(More)
My daughter tried to turn on the dvd player by GE model #DGE505N. The dvd player worked perfectly yesterday. Today, now, when you try to get the player to open and allow me to load a disk it just says "load" and keeps opening and shutting fairly quickly without pause. I unplugged it (because it wasn't responding to any buttons like "open" or "on/off" and left it be for about an hour. Then I plugged it back in. Next it started opening and closing again before I even hit the "on button". I hit the on to see if it would let me do anything and it just kept opening and closing. Before all the opening and closing was a huge issue I was able to retrieve every disk from the player that was in it from yesterday, so I know there is no disk stuck in it. Last bit of info... when you plug it back it (before turning on) it makes a whirring noise, kind of like a fan. I really need to get this thing to work again PLEASE. I am house sitting for my parents and my dad specifically said not to break anything and my daughter is only 2 so she can't keep herself away from buttons. I locked the cabinet but she got it open when I wasn't looking. Please, please, please help me.
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
