I have recently purchased a Sony Camcorder which takes the above discs. While these discs play very...
(More)
I have recently purchased a Sony Camcorder which takes the above discs. While these discs play very well on my DVD player, I can get no sound. Is there some adjustment I must make on the player to get sound? Thanks.
Looking for the unlocking code for the Sansui DVP 1012 DVD Player.. I think its a four digit code?...
(More)
Looking for the unlocking code for the Sansui DVP 1012 DVD Player.. I think its a four digit code? Thanks!! :-)
My GE 5805 P five disc carousel player started giving me trouble powering on a few months ago. To...
(More)
My GE 5805 P five disc carousel player started giving me trouble powering on a few months ago. To get it to turn on I had to manually press the on/off button on the front of the player several times (four to thirty), until the red light above the switch stayed on constantly. Now I can't get it to come on at all, although sometimes the player makes a clicking noise. I should note that when the red light is on, the player is in stand-by mode and can be turned on and off with the remote, which is the way it is supposed to function. I was leaving it in stand-by all the time, but I had a power outage and now it will only make the clicking noise sometimes. Has anyone else experienced a similar problem? I have to fix this because my girlfriend won't come over to watch movies anymore, and now I have to listen to my Wife yell ALL the time! PLEASE HELP!!!
Tried to hook this dvd up to a Samsung LN32A330J1N. The dvd player does not have all 5 composit...
(More)
Tried to hook this dvd up to a Samsung LN32A330J1N. The dvd player does not have all 5 composit hookups on the back. When you hook up what is available the picture is in black/White. Is there a way to hook this up and work correctly. We are at our wits end! Don't want to ditch the dvd player as it has worked great!
I cannot find my product according to either the modle # or the serial number. I'm stumped....
(More)
I cannot find my product according to either the modle # or the serial number. I'm stumped. According to the back it says GE5803PB ,ser# C133PC177 On the front it says GE DVD video It has room for 3 DVD. So trying to find a manual and how to hook it up to my tv. thanks Judy
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
