FixYa.com
Jensen XA2100 Car Audio Amplifier
All Products > Jensen > Car Amplifiers
Problems with Jensen XA2100 Car Audio Amplifier?
Troubleshooting and Support
Solved Problems for Jensen XA2100 Car Audio Amplifier RSS Feed Post a New Problem
Matching a Jensen XA2100 with Sony...
Anyone see a problem doing this? going to set the crossover as high as possible since I'll have some subs to handle...
3 Solutions
Can I hook up an amplifier to my factory...
Can I hook up an amplifier to my factory radio?
1 Solution
I have a new receiver with a preamp...
I have a new receiver with a preamp output, high volume, and I want to feed that into my power amp. Do I need to...
1 Solution
I´ve got 2 amps for my subs,but only...
I´ve got 2 amps for my subs,but only one pre-out from HU of course.i know i should be using amp´s line out to...
1 Solution
Problem
I am having trouble keeping my amp on when I turn up my stereo. I am running it in stereo setting on the LPF and I have...
1 Solution
american legacy II LA690 amp
i want to know if there is any way you can bypass the overhaul (green light:power, red light:overhaul) because when ever...
1 Solution
Need a power connector for a Boss IQ 3KD.1...
Where can I find a replacement power connector for a Boss IQ 3KD.1 3000W Class D Monoblock Amplifier. The screw loosened...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Jensen XA2100 Car Audio Amplifier RSS Feed Post a New Problem
I lost my hook for high input,
where can i get a new one or how do I select the rigth one, I mean its has 6 differents lines, how do I know which one...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Amplifier TypeDual Channel
Power Output
RMS Power at 4 Ohms.08 W x 50
RMS Power at 2 Ohms1 W x 50
Performance
Bass Boost Frequency50 Hz
THD at Rated RMS Power250 %
Signal to Noise Ratio83 dB
High - Pass Frequency150 Hz - 20 Hz
Dimensions
Height2.25 in.
Width45 in.
Jensen Contact Information
Main support number800-645-4994
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
