20 Most Recent
Magnavox 19MD357RB 19 in. LCD TV Questions & Answers
VCR/DVD code for a Magnavox?
Your question is lacking in details.
You have an unknown make of VCR or DVD and you want the Magnavox television to operate them?
Or you want the VCR and DVD remote to operate the television.
Or you want a Universal Remote and a magic code to make all three work?
The answer to all three is No, apart from number 3 where a very expensive LCD computerized remote can control multiple items.
No one uses Universal remotes, there are better options. Codes are based on the MAKE of the unit to be operated, so Philips DVD you want a Philips DVD remote code. For the Magnavox, you want the code for a Magnavox television IF in fact it is a television and not the VCR/DVD, which now I am thinking is actually what you are after, so we end up here!
https://theproductanalyst.com/magnavox-dvd-vcr-combo-remote-codes/
But better to buy a remote actually made for that unit as explained here.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
12/2/2023 12:55:29 AM •
Magnavox...
Answered
on Dec 02, 2023
I have a Magnavox clo358 universal remote what are the codes for my Magnavox DVD VCR combo
To program your Magnavox DVD VCR combo using the Magnavox CLO358 universal remote, you can try the following codes:05030675115312031321Here's how you can program the remote:Turn on your Magnavox DVD VCR combo manually.Press and hold the "Code Search" button on the remote until the indicator light turns on.Release the "Code Search" button.Press and release the mode button for the device you want to program (in this case, the DVD VCR combo). The indicator light should remain on.Enter one of the codes listed above using the numeric keypad on the remote. The indicator light should turn off after entering the code.Aim the remote at the DVD VCR combo and press the "Power" button. If the device turns off, the code is correct. If not, repeat steps 4 to 6 with the next code on the list.If none of the codes work, or if you have any other issues, it's recommended to consult the user manual of your Magnavox CLO358 universal remote for additional instructions and a complete list of codes.
8/28/2023 5:54:07 PM •
Magnavox...
Answered
on Aug 28, 2023
What code is needed to get a Dish remote to pair with a Magnavox soundbar msb4550?
Magnavoxsound bar codes 0110, 0115, 0044, 0058, 0086, 0091, 0018, 0116, 0123, 0126, 0040
4/3/2023 10:17:56 PM •
Magnavox...
Answered
on Apr 03, 2023
Need Repair Help with a Phillips Magnavox TV Model 15MF605T/17
It is possible that the main board of your Phillips Magnavox TV Model 15MF605T/17 is damaged or blown. However, before assuming that the main board is the problem, you can try a few troubleshooting steps:
- Check the connections: Make sure that all the cables and connectors are properly connected to the TV and the power source. Disconnect and reconnect all cables to ensure that they are secure.
- Reset the TV: Unplug the TV from the power source and wait for a few minutes. Then plug it back in and turn it on. This can reset the TV and fix any software issues.
- Test with another power source: Try plugging the TV into a different power outlet or using a different power cable to rule out any issues with the power source.
If none of these troubleshooting steps work, it is possible that the main board is damaged and needs to be replaced. You can contact a professional repair service for further assistance or consider purchasing a new TV if repair costs are not feasible.
3/18/2023 5:58:14 PM •
Magnavox...
Answered
on Mar 18, 2023
