20 Most Recent Kenwood KAC 6201 Car Audio Amplifier Questions & Answers
check pwm chip ,may need replacing
Kenwood KAC 6201... | Answered on Nov 30, 2014
have you checked the earth wire make sure that is in a correct placement also check the earth on your cd player brown wire
Kenwood KAC 6201... | Answered on Sep 27, 2012
you probably have a shorted part inside the amp
Kenwood KAC 6201... | Answered on Aug 31, 2010
the remote wire is on the power wire that stays on all the time on the back of the head united there is a blue with white wire the remot has to go to that one.
Kenwood KAC 6201... | Answered on Aug 13, 2009
Make sure you have voltage to both the main power input and remote. Without remote power the amp will not turn on. If you check with a light or meter and you positively have voltage to both power inputs and a good ground, and you still have no power, the amp is defective. I hope this helps...
Kenwood KAC 6201... | Answered on Oct 18, 2008
The Kenwood KAC would be 2 ohm stable.
I ran my sub's in parallel and the amp did not shut off and hit pretty well for long periods of time.
If you are running two dual voice coils.
Bridge amp, run pos and neg to pos and neg outside of box.
neg and pos to one side of sub
The other side of the sub run to the next sub
the other side of the sub to the inside of the box pos and neg.
pos and neg outside of box to the other outside terminals to create a complete loop.
If this isn't a good description post back and I'll email you a picture of it.
Kenwood KAC 6201... | Answered on Apr 03, 2008
It should be better to use the Pioneer GM-7200M Amp with your subs.
For 8 ohm setup hook up this way:
Amp out+ to Sub1 +
Sub1 - to Sub 2 +
Amp out - to Sub2 -
For 2 ohm setup hook up this way:
Amp + to Sub1 +
Sub1 + to Sub2 +
Amp - to Sub1 -
Sub1 - to Sub2 -
Kenwood KAC 6201... | Answered on Nov 11, 2007
Download the model number, then put operators manuel.
Kenwood Car... | Answered on Aug 26, 2019
Hi Karen, you can download the manual from the internet to a USB memory and then print it or send it to print on the sheet size you like best and you would already have it on paper
I send you the link to download
Regards Franco Dosil
Hola Karen, puedes descargar el manual de internet a una memoria USB y luego lo imprimes o lo mandas a imprimir en el tama?o de hoja que mas te guste y ya lo tendrias en papel
te envio el link para que lo descargues
Saludos Franco Dosil
http://manual.kenwood.com/files/509335ef87853.pdf http://manual.kenwood.com/files/509335dbbeee5.pdf
Kenwood Car... | Answered on Aug 24, 2019
Hi Lisa, as you say, it is very likely that the Laser reader may be dirty or the reader's progress locked
Consult a specialized technical service
Hola Lisa, por lo que comentas, es muy provable que pueda estar el lector Laser sucio o trabado el avance del lector
Consulta a un servicio tecnico especializado
Kenwood has the manual for the KDC-U346 available through the Car Electronics support page: https://www.kenwood.com/cs/ce/ . Enter the model number and click the search button. Click on the link to your model's support and scroll down to find the manuals. The current link to the KDC-U346 manual in English is http://manual.kenwood.com/files/4acea67631aca.pdf . This manual covers several Kenwood models.
I hope this helps.
Kenwood Car... | Answered on Aug 16, 2019
Kenwood KAC 6201 Car Audio Amplifier Logo
Popular Tags
8 questions posted
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Car Audio & Video
Most Popular Question
amp will not turn off remote wire
  • Car Audio & Video
