Troubleshooting & Support
Hot Topics:
- 673r kenwood...
- ipod
- wiring diagram
- buttons
- kd g340
- Kenwood KMD
- minidisc
- 671r
- install
- clock setting
- won play
- reset player
- best love song
- x92
- kd s35 manual
- kd g245 manual
- r55
- power
- demo mode turn
- please eject
- kd
- memory wire
- install stereo
- kd s16
- ipod restricted
- rerecord
- kenwwod...
- clock set kd
- kd s14 clock
- mini
- View All »
Problems & Solutions
replacing current stereo with my
are both the red and yellow wires getting power?
how to put song in the disc of mini disc
You need a mini disc recorder to load songs to the disc. it's similar to burning a cdrw disc in your computer.I have a Pioneer PMD-R55-S...
Kenwood KMD 673R and scrolling for MD title ?
In article <780b957c.0403171248.5ad73 @posting.google.com>, colin1dup @yahoo.fr says... Generally... When you do a RESET it...
kenwood kdc-x689 wiring diagram
The wiring diagram is on page 40 of the manual.
no power to my new kenwood. i put red to
Check also the fuse on your kenwood or the fuse that attached on the red wire.
I have a kenwood mp5033 head unit to which I'm
I read in the manual that you need the KCA-S210A auxiliary input. I have a link, the information I read is on PAGE 20....
How do I set the clock on my kenwood hdc438u
Put the headunit on STANDBY. press the menu/M.jog button down for 1 second. Select CLK ADJ. Press Control button for 1 second. You now have...
I have a problem in
do you mean when you close the door of the car or the ignition switch? If it is the door then there is a very strong possibility that the...
I had my system installed by a professional and it
it sounds like the installer used the blue wire (antenna remote turn on) instead of the blue/white (amplifier remote turn on) to power up...
i have a model krc-501 radio/tape player in my
did you check the voltage to the radio with a multimeter? if the voltage is less than 10 volts, the radio will not work.
i have a kenwood krc-12 cassette receiver to hook
it costs 12 bucks for the plug and wiring harness at wall mart for chryler/ jeep.with the wiring harness instructions are on or in the...
my memory wire is yellow & my power wir is
The red wire goes to the ignition 12 volt source, and the yellow to the battery 12 volt source. The yellow wire must remain hot with the key...
No sound when ipod connected to my Kenwood dnx6140
You need the optional accessory KCA-ip301V cable
wont shut off
You have the accessory (red) and the 12volt memory (yellow) switched.
Unsolved Problems
I'm thinking of getting a
I'm thinking of getting a KENWOOD KMD-673R, I've seen one for sale; but I need Aux i/ps so that I can use an...
fitting instruction manual or user manual for
fitting instruction manual or user manual for kenwood KMD673R minidisc wiring diagram
Manuals & Guides
TopDo you have a manual for Kenwood KMD-673R MiniDisc Player? - Upload it to FixYa!
Upload a manual for Kenwood KMD-673R MiniDisc Player
Specifications
TopKey Features
Full Product Name:Kenwood KMD-673R MiniDisc Player
Player Type:MiniDisc
Controlled Devices:CD Changer
Controlled Devices:Mini Disk Player
Amplifier / Speakers
Built-In Power Amplifier:Yes
Built-In Amplifier Power:4 x 45 Watt
Radio
Tuner Type:FM / AM
FM Presets:18
AM Presets:12
What's your problem?
Fix-O-Meter
412
412 people have viewed this product
- 5 people asked about this product.
- 3 people found solutions for this product.
- 0 people have added this product. Be the first!
How to Enter a...
How to reset...
Basic wiring...
