20 Most Recent Lenovo IdeaPad S10 (59019956) Netbook Questions & Answers
2answers
The one key recovery was used from the desk top of
you need a programm to recover your data
3/8/2011 7:29:32 AM • Lenovo IdeaPad... • Answered on Mar 08, 2011
3answers
My Lenovo IdeaPad G560 turns on, but has only black screen, what should I do?
here it is, youtube, 1pm seen here, see blue coded soldered down ML1220 coin cell your CMOS NVRAM battery is there. https://youtu.be/z1EjNOEy6Do?t=268 just above CPU brace left top screw. BI NGO this one model, of may submodels. the life span is 5 years, but never parked for 7y ever. parking it allows it to go OVER discharged, and now dead faster. if not there you are in a different country.
5/4/2022 1:22:11 PM • Lenovo IdeaPad... • Answered on May 04, 2022
4answers
HOW TO EJECT A DISC IN LENOVO IDEAPAD 330
The CD/DVD drive may be opened by pressing a button on the drive itself. If the drive does not open by pressing a button on the drive itself, or the button is not available on the drive, Windows natively provides the ability to eject the tray with simple methods that can be performed in the File Explorer. The steps vary from different operating systems:
  • Windows 7
  • Windows 10
Note:
  • Not all systems come with a CD-ROM, CD-RW, or DVD drive installed internally to the computer
    • To verify that, you can check the left and right side of your machine. See if there is any slot to insert your CD/DVD. Normally, there is a button to eject the CD or DVD tray for you to insert a disc
    • Another method to identify this is as below: 1. Click Start and type Device Manager in the search box. Select Device Manager 2. In Device Manager look for DVD/CD -ROM Drives If you don"t see DVD/CD -ROM Drives this means your device has no optical drive hardware. An external optical drive will need to be purchased to run CD/DVD. It is also wise to check your product specification to see if your device has an optical drive. If you were previously able to play CD/DVD and DVD/CD -ROM Drives has disappeared from device manager or your device is not reading the disc please follow > Your CD or DVD drive is not recognized by Windows or other programs.
  • The format capabilities of the drive are listed on the label on the external cover of the drive
  • The CD-ROM, CD-RW, or DVD drive can be opened using the emergency eject hole (Bend away a leg of a paperclip to work with. Insert the paperclip slowly until there is resistance, then gently push until the drive door is opened) Applicable Brands
    • ThinkPad
    • IdeaPad
    Solution ·Windows 10 ·Windows 7 Eject disk tray with File Explorer
    1. Turn off all applications currently using the drive. Otherwise Windows will prevent you from ejecting the DVD tray
    2. Hold Windows + E on the keyboard to open File Explorer
    3. Click the DVD drive icon and click the "Eject" button on the toolbar or right-click on the optical drive and choose Eject from the menu that pops up or down.
4/27/2021 1:51:55 PM • Lenovo IdeaPad... • Answered on Apr 27, 2021
Lenovo ideapad s145 my Screen turns white and does nothing after entering phone number during setup
If you bought the Lenovo at a local dealer, take it back to them. If you bought it through an online dealer, I recommend you track down Lenovo customer support.
9/5/2019 6:29:58 PM • Lenovo IdeaPad... • Answered on Sep 05, 2019
Win 10 lenvo ideapad 320 will not play mygames now
really why not ask the game maker directly for help with your w10. here they are right>? https://www.mygames.com/ so what do THEY say , it is there code, running. does Tetris fail or just your games, unnamed, this maker is bad company they take over your PC why run this crappp? it takes over your browser, and more, and is bad. the do not even have minimum system requirement there. nor support. avoid like the Plague.
6/30/2019 1:32:19 PM • Lenovo IdeaPad... • Answered on Jun 30, 2019
I have error C0000034 applying update operation 460 of 41831 (generalize XML). All I did was turn my idea pad on. It never resolves and I have tried turning my laptop off and restarting. Any ideas
Restart your computer & start tapping f/8 immediately and keep tapping until black screen comes up. Use the arrow keys to select safe mode the press enter. It will start up in safe mode in each corner, the icons are all out of shape and a help window will open. Close that window. Then go to: Start, Accessories, System Tools, right click System Restore & send to desk top.(The reason to do that will be to use it easier ANYTIME you have a problem.) Then do a system restore back to a time before you had the problem. That should resolve it. If not you will have to do a Recovery after saving everything you want to keep on a Flash Drive. On start, type recovery & go there & follow directions. I’m happy to help further over the phone at https://www.6ya.com/expert/wynn_5ba0205233ebfc15
4/16/2019 6:12:01 PM • Lenovo IdeaPad... • Answered on Apr 16, 2019
When I flip my screen whilst watching a video on
It's a mechanical problem with the wiring and contacts along the edge of the screen. No "fix" except screen replacement.
4/1/2019 2:16:47 AM • Lenovo IdeaPad... • Answered on Apr 01, 2019
2answers
When laptop start window 10 boot screen come up and during the process after 15-20 seconds since the laptop was powered on the laptop get shut down.
hi there. Laptop performance slowing down, or the laptop isshutting off completely because the laptop is trying to protect itself from damage caused by an excessive heat build-up. ... There are times when a laptop will turn offbecause of a virus or malware, hardware or software problems/conflicts as well.2 Nov 2013
Don't panic!... Is your "laptop shutting off by itself" or "slowing down ...
https://www.youtube.com/watch?v=74agkgZdzkI What is the problem if laptop shuts down automatically?If removing air doesn't fix shutdown issue, it is a faulty hardware (can be anything), related to overheating or serious power related failure, such as bad battery or adapter. Overheat issue will result in unit turning on, but shuts down after about the same time (i.e. 15 sec).29 Jun 2015My Laptop automatic shutdown in few seconds - Laptops - Laptop ... What would cause a computer to keep shutting down?An overheating power supply, due to a malfunctioning fan, can cause a computer toshut off unexpectedly. Continuing to use the faulty power supply can result in damage to the computer and should be replaced immediately. ... Software utilities such as SpeedFan can also be used to help monitor fans in your computer.5 May 2017Computer turns off without warning - Computer Hope How do I get my computer to stop shutting down?Cancel System Shutdown or Restart. You cannot cancel a restart or shutdown using the Shutdown Event Tracker Windows interface. It is only possible to perform this task from the command line. To cancel or abort system shutdown or restart, open Command Prompt, type shutdown /a within the time-out period and hit Enter.1 Apr 2013Stop, Cancel, Prevent, Abort System Shutdown in Windows 10/8/7www.thewindowsclub.com/abort-system-shutdown-windowsSearch for: How do I get my computer to stop shutting down? or go to this link to find out more. Laptop keeps shutting off after few minutes
1/23/2019 11:58:48 AM • Lenovo IdeaPad... • Answered on Jan 23, 2019
Lenovo ideapad 330S -. Screen went black, power light and numbers light on, does not respond to any key on the keypad. Lenovo ideapad 330S
Lenovo ideapad 330S330S-nnnnnn what is the sub number on model.nnnnnn is 11 to 17 and up to 3 latters at the end.4 years old max 2015 made.answering for dead screen, no text, no lenovo logo icon on screen.no prompts, and BIOS hot keys are dead. ok?remove AC pack and all usb devicespush power button for 10 to 30 seconds and releasethis is Forced cold power restart,NOW is this a cure to the problem?> with power pack put back in? plugged end to end, AC wall to PC.OK no is not:remove AC power pack. unplug it)next is the more hard, remove PC covers 10 screws. page 34and unplug the battery connector.as seen on page 36 of your service manual below.then plug in the AC Power pack now.does the PC run ok with no 4 year old battery inside? end no battery test,what was the results now?moving the battery inside any PC does not make it last longer, only harder to remove and service.the price we pay for Light and thin."higher cost of ownership"see page 36https://download.lenovo.com/consumer/mobiles_pub/ideapad_300s-11ibr_hmm_201509.pdf you asked I told.
1/19/2019 12:04:03 PM • Lenovo IdeaPad... • Answered on Jan 19, 2019
Itunes freezes
Try getting the latest version of iTunes, or reinstall your current version.
11/13/2017 9:08:51 AM • Lenovo IdeaPad... • Answered on Nov 13, 2017
WINDOWS 8 PREVIEW INSTALLED ON LENOVO IDEAPAD AND IS NOT WORKING PROPERLY SO TRYED TO RECOVER TO WINDOWS 7 BUT NOT WROKING!!!!
You will need a separate recovery disk. Sounds like the recovery partition of your HDD got overwritten. Maybe you can create a windows WinPE (microsoft docs) and use that. This says what to do once you have a recovery disk. https://pureinfotech.com/how-to-uninstall-windows-8-developer-preview-and-restore-windows-7-step-by-step/
9/25/2017 1:12:10 PM • Lenovo IdeaPad... • Answered on Sep 25, 2017
2answers
How do i remove or reset the bios password on a Lenovo G580 laptop?
First of all, you need the present password. Then straight after turning the computer on you press F12 or insert multiple times after each other. That way you will stop the normal boot and enter the BIOS settings. There you most likely will be prompted for the password and then under security you can disable or change it.
6/26/2017 4:53:15 AM • Lenovo IdeaPad... • Answered on Jun 26, 2017
My laptop does not appear on your computer list
Each computer on your network should have network discovery turned on. They should also be a part of the same group or network. The default in Windows is WORK, but you can change the name to whatever you would prefer. How to Turn on Network Discovery in Windows 7 I’m happy to help further over the phone at https://www.6ya.com/expert/james_d4449ffdf318a2c3
7/18/2016 6:36:07 PM • Lenovo IdeaPad... • Answered on Jul 18, 2016
I can't configure. Stuck at the next page after connecting wireless.
Use Internet Explorer ?
3/18/2016 7:00:52 AM • Lenovo IdeaPad... • Answered on Mar 18, 2016
Lenovo IdeaPad S10 (59019956) Netbook Logo
1 questions posted
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
IdeaPad Lenovo
  • IdeaPad Lenovo
Most Popular Question
one key recovery used from desk top
  • Computers & Internet
