20 Most Recent Kenwood VR-6050 Receiver Questions & Answers
It usually means something is drawing too much current---a short inside the unit----idea is to prevent a chain reaction that frys half the unit.
Consider having a shop look at it and do check to make sure all the connections are correct.
Kenwood VR-6050... | Answered on Dec 04, 2012
Kenwood sound units are probably market leaders in most parts of the world because of the durability and high standard of their products. When loud screeching sounds and static is are heard on sound systems in most cases it is as a result of poor wire connections to the speakers. Check the wires to the speakers most likely the screeching and static is coming from those.
Also static could also be caused by mobile devices being close to the receiver. Mobile devices such as internet modems and mobile phones as well as radio transmitting devices could cause static and screeching.
Hope this solution has been helpful?
Kenwood VR-6050... | Answered on Nov 21, 2012
The following are the best I can do without specifics re: your TV and other TV-related equipment.
Since a TV without an antenna is rarely the source of any programming it is best to feed the receiver the best sound available from the device where it originates - cable / sat / DVD / BluRay / games. Your receiver probably has plenty of inputs to accomodate al of these. I also run the video directly to my TV, which has several video inputs, from each source because IT deserves the best unadulterated video.
If you have a cable box and want the best sound, get it directly and digitally from the cable box and run it to the receiver. Then leave the TV's speakers off for critical viewing with good sound.
Kenwood VR-6050... | Answered on Oct 19, 2012
This is a problem with the output transistors that power your speakers. This is a problem for a professional unfortunately.
Kenwood VR-6050... | Answered on Mar 16, 2011
May I ask what the problem is. If you need the manual you can get it on the link below.
http://support.radioshack.com/support_audio/doc69/69230.pdf
Thank you
Kenwood VR-6050... | Answered on Nov 29, 2010
that reciever is not going to carry a hi definition video signal, it doesnt have either hdmi or component video inputs.
you can still use it, but if you run the picture through the reciever, it will have poor quality.
heres how you are supposed to hook it up:
find the single,m yellow video jack on your sattelite box, and hook that up to the "tv" video input, then hook the laft and right audio outputs from the cable box into the "tv" audio left and right inputs on the receiver. hook up the dvd player and vcr in the same manner, using "dvd" and "VCR" (if labeled as such) inputs on the reciever.
finally, send the tv video and audio outputs to the composite video in and left/right audio inputs on the tv. the video will be running through the reciever, and when you use the reciever to switch the sound source, the video will also be changed. you could get better picture quality if you ran the video directly to the tv using component (seperate green, red and blue) outputs/inputs, and bypassing the reciever on the video end, but then you would have to change inputs on the tv AND reciever to change from your cable box to your dvd player.
Kenwood VR-6050... | Answered on Nov 25, 2010
Go to kenwood website they have it
Kenwood VR-6050... | Answered on Jul 23, 2010
To an extent. Sound-wise, yes. It has 5.1 analog inputs.
Kenwood VR-6050... | Answered on Dec 27, 2009
It will be one of the drive belts , its better to get a repair shop to replace both belts , i have tried replacing belts myself and they are fiddly and time consuming , if you keep playing it the way it is you will damage the motors that turn the belts
Kenwood VR-6050... | Answered on May 24, 2009
http://www.docstoc.com/docs/1303225/Kenwood---VR-6050---VR6050pdf---Owners-Manual---English
here is the manual
Kenwood VR-6050... | Answered on Apr 26, 2009
you may have a dc condition present on speaker outputs. this could be caused by dry solder joints, suggest blanket resolder of the output stages for front channels.
Kenwood VR-6050... | Answered on Dec 13, 2008
Ummm.... your question is about a car radio, but you listed a home amp as the unit..... ?!? Anyway if it's a kenwood CAR radio, pressthe "ATT" button and it should go back to normal volume.
Kenwood VR-6050... | Answered on Sep 10, 2007
Kenwood VR-6050 Receiver Logo
22 questions posted
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
rigger094
Mike Duncan
Mike Duncan
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Audio Players & Recorders
Most Popular Question
hook up tv sound play
  • Audio Players & Recorders
