Home
My Products
Sign In
All Products
Panasonic
Car Speakers and Subwoofers
Problems with Panasonic CJ-A1600 Coaxial Car Speaker?
Add to Warranty Manager
Search inside
Knowledgebase
Troubleshooting and Support
Post a New Problem
How do I know what speakers fit my car?
1 Solution
Intermittent Problem
Sub plays for a while, then stops, then plays again, sometimes several times within the same song. Sometimes makes a...
1 Solution
What about component speakers - Do they...
What about component speakers - Do they sound better?
1 Solution
low level noise causing sub flutter
I have an 02 alero. I have installed vega subs and an amp. I have managed to get power and tunes but when the radio is...
2 Solutions
honda accord speakers
got car back from stepson and the speakers don't work (cd or radio)....the unit itself is working, just no...
1 Solution
no sound comming from car speakers
system works but no sound.
2 Solutions
kicker solobaric l5 12''
proper wiring of sub for connection to a crunch 1 ohm stable 600 watt amp
2 Solutions
View All
Tips & Tricks
Post a New Tip
How to install speakers and Subs
- Written by
DrElectrics
WikiManual
Post a New Chapter
Be the first to Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Be the First to upload Manual or Guide
Specifications
Key Features
Type
Coaxial
Elements
2-Way
Function
Tweeter, Mid-Range
Size
6.5"
Powered
Non-Powered
Nominal Power Handling
60 Watt
Technical Features
Peak Power Handling
120 Watt
Frequency Respond
35 Hz - 22,000 Hz
Sensitivity
92 dB
Impedance
4 ohm
Components
Tweeter Design
Dome
Woofer Material
Poly / Plastic
Surround Material
Foam
Mounting
Enclosure
Non-Enclosed
Panasonic Contact Information
Main support number
800-211-PANA
Sponsored Links
Bogda
Let one of our
Experts Solve
your Problem
DO YOU WORK FOR
PANASONIC
Register as STAFF
New Products
Powered by
Repair Service
Find Car Speaker and. Repairman Near You:
Advertise Here
powered
by
Get this Widget
