20 Most Recent
Denon AVR-2311 Receiver Questions & Answers
I have connected to my 2311: HDMI 1: Oppo BDP 83
hi,
You have to check the digital audio assignment of you AVR for HDMI 1 and HDMI 2. There is three options for the digital audio for HDMI 1 and HDMI 2. You can set it as optical ,coaxil, or the HDMI itself. In you receiver the assignment may be in optical input or in coaxial input for the two HDMI inputs.
1. Go to the system setup
2. Select input setup
3.Select input assignment.
4. Select all the three input ,you are using as HDMI
ok
Size of fuse for Denon dra 697
The Denon DRA-697CI stereo receiver typically uses a 250V, 2.5A fuse. However, it's always a good idea to consult the user manual or check the label near the power input on the device itself to confirm the exact fuse size and specifications for your particular model. Using the correct fuse size is important for safety and to prevent damage to the receiver. If you're unsure, you can also contact Denon customer support for assistance.
Fuse size for Denon DRA 697 c!
The Denon DRA-697CI is a stereo receiver. Typically, the fuse size for electronic devices like stereo receivers is listed in the device's manual or on a label near the power input. It's important to use the correct fuse size to ensure proper protection against electrical faults.
Without specific information about the fuse size for the Denon DRA-697CI, I recommend consulting the device's manual or contacting Denon's customer support for accurate information. Using the wrong fuse size can potentially damage the device or pose a safety hazard, so it's crucial to verify the correct specifications.
