20 Most Recent
Samsung DualView TL205 / PL100 Digital Camera Questions & Answers
There are black spots on the viewer screan. What is the fix?
I dont know wheather the black do t is coming in your picture also (after down loading you can seee) if yes you hace to clean your ccd/filter etc. If the dot not coming into you picture then you have to clean ur LCD.CONSULT A CAMERA DOCTOR.
My Samsung Pl100 will not
Having gone over two months without a response to my query, I assume my suggestion to use a card reader solved the problem.
My samsung pl100 jas a
Two things there, first... could be a problem with the viewer screen, or, second choice could be a problem with the CCD sensor or go to bad; in both cases this isn't a job that you could solve yourself; this wrong include distorted images or abnormal colors, scratchy purple lines,
blank or black pictures, and/or black videos with good sound being
recorded on the camera's flash card.
I suggest check THIS LINK for additional details in this previous solutions for an Defective CCD
(Charge Coupled Device) and next contact your Samsung service. I strongly suggest (taking into consideration the age of your camera) to evaluate the cost of repair versus the cost of a new camera with similar features, before making a final desicion.
Hope this helps.
I have a Samsung PL100 (Dualview). I'm having
i find that alot of times using the camera to unload your pictures to your computer is more trouble them you need to worry about. i say you just pull out the SD or SDHC card and plug that into you computer. if you dont have an SD or SDHC card reader in you computer you can pick up a cheap one for a few dollars online.
