20 Most Recent Panasonic CT-32HX41 32" TV Questions & Answers
Hello... This sounds like a convergence issue, but I didn't think they made rear-projection TVs as recently as 2013? Also, your post says you have a 32"? If it's a 32", then ignore the following.
If it is a convergence issue, parts will need to be replaced. There are usually two STK ICs and maybe some resistors that can go bad.
I hope this helps!
Panasonic... | Answered on Nov 27, 2017
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Panasonic... | Answered on Apr 05, 2017
Once you take the back off there is a glass gma fuse withing a few inches of where the power cord plugs into the board at. This should be a 6.3 or 6.5 gma fuse. Very common to blow in your model because the degausing coil is a little to big for it. There are other reasons for it to blow but 99% of the time you change change it and the set will work again. Let me know if you need more help or info!
Tim Nolan
Panasonic... | Answered on Sep 04, 2010
No reset or magic button but the problem could be C524 Panasonic p/n# Ecqb1224jf off pin 10 of the flyback. These are a VERY common failure in that unit causing everything from shutdown to dead condition.. It wouldn't be that expensive either to have that estimated and repaired. I think you would be pleasantly surprised.
Bill
Panasonic... | Answered on Nov 28, 2007
Hello zang,
This denotes a problem with the switching power supply or the high voltage power supply. what is happening is the safety relay is being actuated by the shutdown circuit. Any number of things can cause this proble but more then likely the problem is in the high voltage power supply section and or its associative circuitry. The switching power supply and the high voltages power supply have very dangerous voltages and I would not suggest that you work on the TV set unless you do have a background in electronics. If you do not I would suggest that you take the TV set to an electronics shop for repairs. If you do have a background in electronics, you will need the following items:
1) A schematic diagram (to know where voltage and signal test points are located and to have a reference of the levels.
2) A multimeter (to measure the DC voltage levels on the TV Set)
3) An oscilloscope (to measuer the AC voltage and signal levels in the TV set and compair them to the values in the schematic)
4) A signal generator (to generate a reference signal for troubleshooting)
I hope this helps,
Shuttle83
Panasonic... | Answered on Oct 11, 2007
In set up, cc on mute set to no overrides mute selection on your remote control so cc stays on.
Panasonic... | Answered 7 hours ago
Hi Mohammad Hooshmand, indicates model of the Panasonic DVD you are commenting on, in order to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola Mohammad hooshmand, indica modelo del DVD Panasonic del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
Panasonic... | Answered 2 days ago
Plasma TVs do run hotter than LED TVs. I suggest placing your TV into power saving mode which should reduce the heat.
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Do you mean Directv app? You'll need an Amazon Firestick or equivalent and stream the app from a laptop or desktop computer. You'll need to be a subscriber to use the app.
Panasonic... | Answered on Sep 02, 2019
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
https://homenol.blogspot.com/
https://remotesearch.blogspot.com/
https://electronicshelponline.blogspot.com/
https://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. See the site by a desktop. Mobile view has no search box. If you are viewing it by your mobile, see it in webview]/
Panasonic... | Answered on Aug 26, 2019
Hi Donald, I have passed the link to download the user manual
Regards Franco Dosil
Hola Donald, teb paso el link para que descargues el manual de usuario
http://www.manualsbase.com/es/manual/130982/dvd_recorder/panasonic/diga_dmr-es35v
Panasonic Diga DMR ES35V Instrucciones De Funcionamiento
Panasonic... | Answered on Aug 22, 2019
Panasonic CT-32HX41 32" TV Logo
7 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
turn
  • Televison & Video
