20 Most Recent Panasonic TX-36PF10 TV Questions & Answers
Oh dear.
It sounds like you have magnetised the screen by placing something magnetic too close.
Your only hope is to unplug the TV, and remove ANYTHING magnetic away from it, such as speakers etc. Give it a few hours then retry.
If this has been going on some time, it will already be too late.
The other possibility is the tube could be going!
Panasonic... | Answered on Jan 10, 2018
If your Panasonic TX-36PF10 is 10 years old, it probably is time to think about replacing it.
Panasonic... | Answered on Dec 07, 2017
IF this is the 36" model this thing is going to be close to 100 lbs.
Panasonic... | Answered on Dec 31, 2012
Its what we call a purity problem on this 36 inch set and only two things cause it, the set (not getting too technical) uses a single part connected inside that when set is turned on powers a large coil around the picture tube--it just demagnetizes the tube---what happens is there is a single black square part there not much bigger than a cube of sugar---easy to spot as it will have three leads in a triangle shape---
What you will likely find if you can get the set apart---Its a real heavy set is follow the power cord to the board---real high chance you will find one of the three leads on that part has broken loose from the board, happens from all the heat at turn on that part gets real hot for a very short time.
You would be smart if one lead has come loose to solder all three---the part is often referred to as a thermistor--as it gets hot it cuts voltage off to the coil.
The other possible cause is only possible if set fell forward or was dropped, in that case the damage is fatal and cannot be repaired.
Let me know if questions.
Panasonic... | Answered on Dec 11, 2012
Pressing the ident key on the remote controller will fix that. It has a toggle action. Press for on and press again for off.
Panasonic... | Answered on Dec 28, 2010
Unplug Then Hold Power On/Off For 30 Seconds Then Release And Plug It Back In.
Panasonic... | Answered on Jan 18, 2009
The power supply could be failing - erratic operation
Panasonic... | Answered 3 days ago
Google (Panasonic)(me17h7035shb)(manual) without parens.
Panasonic... | Answered on Sep 14, 2018
Shorted circuit board
Panasonic... | Answered on Sep 10, 2018
Panasonic TX-36PF10 TV Logo
Popular Tags
12 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
weight tx 36pf10 tv
  • Televison & Video
