20 Most Recent Sony VAIO VPCCW21FX Notebook Questions & Answers
Call Microsoft Support. They will walk you through the procedure.
Sony VAIO... | Answered on Nov 10, 2016
get it here http://esupport.sony.com/US/perl/swu-download.pl?mdl=VPCCW21FX&upd_id=4859&os_group_id=6
Sony VAIO... | Answered on Dec 02, 2013
hola asegurese de tener el driver correspondiente instalado, a veces si no lo tienes actualizado o bien usas el default no funciona bien la el motion eye
Sony VAIO... | Answered on Nov 30, 2013
Defective video module on motherboard. Buy new laptop. Not worth buying a replacement motherboard and getting the same problem again.
Sony VAIO... | Answered on Nov 04, 2013
if any drive is not shown then it must have harddisk failure or mother-board problem ... as per my knowledge . i have repaired atleast 50 computers for such kinds of problems
Sony VAIO... | Answered on Jun 09, 2013
Is that a question?
Sony VAIO... | Answered on Apr 17, 2013
ALL CD's or just one CD? Depends on the file format and the Media Player. Have you tried another Media Player? Does the CD work in another Computer? Did you make the CD? What is the Media on the CD?
Sony VAIO... | Answered on Mar 21, 2013
Step 1:
The scrolling feature on a laptop touchpad can take some getting used to, which causes some users to disable the feature. Whether scrolling was intentionally turned off or never enabled on the laptop, it can easily be turned on from the "Mouse Properties" menu.
Click "Start" (or the Windows logo button in Vista and Windows 7) and select "Control Panel." Select "Classic View" in Vista if not already displayed. Double click "Mouse." You may also access "Mouse Properties" in Vista and Windows 7 by clicking the Windows logo and typing "Mouse" in the search box. Press "Enter," then click "Mouse" when the search is finished. Select the "Hardware" tab. Select the touchpad and click "Properties." Click "Change Settings" if the settings aren't displayed. Click the "Device Settings" tab in Windows 7 and select the touchpad. Click "Settings." Click "Virtual Scrolling" in the touchpad properties window. Click the boxes next to each "Enable Scrolling" box and click "OK." Scrolling is now turned on for your touchpad.
Sony VAIO... | Answered on Feb 25, 2013
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
hope this helps
Sony VAIO... | Answered on Oct 08, 2012
The motherboard is getting to hot, it will need to be dismantled down to the main board, you need to verify the cooling fan is working properly, next remove fan and heatsink, get a can of compressed air and clean out all clogged ports and fan, now remove old thermal paste with rubbing alcohol and a paper towel and apply fresh compound to the processor and heatsink, small amount and spread evenly then assemble.
Sony VAIO... | Answered on May 27, 2012
is the fan coming on if not you may need to replace the fan...however if it is it may need to be cleaned the air passage or heat sink may be clogged. This is easy to do, however if its your first time cleaning refer to service manual for dissasembley. A quick fix may be to us compressed air and spray in the fan exhast; that may open clogged air passage.
Sony VAIO... | Answered on Sep 09, 2011
MR. PRAVEEN IF YOU HAVE A USED A PIRATED COPY THIS PROBLEM OCCURS. IF YOU ARE USING A REGISTERED S/W THEN YOU HAVE TO UPGRADE FROM THE MICROSOFT UPDATE SITE.
REGARDS.
PLZ. DON'T FORGET TO RATE
Sony VAIO... | Answered on Jul 05, 2011
Follow these steps
First you should Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including BSODs.
- Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in safe mode then update your graphic drivers from the manufacturer site of your laptop
Let me know if it helps you.
Use system utility tool like RegInOut to remove unwanted files , fix registry and windows errors which causing blue screen
Sony VAIO... | Answered on Feb 19, 2019
Sony VAIO VPCCW21FX Notebook Logo
45 questions posted
Top Sony Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
VAIO Sony
  • VAIO Sony
Most Popular Question
webcam driver para sony vaio vpccw21fx
  • Computers & Internet
