20 Most Recent Panasonic CT-32G23 32" TV Questions & Answers
no power red led work
Panasonic... | Answered on Dec 12, 2015
Go to tv menu go to screen setting turn screen contrast to the max and screen brightness half midway point like 55.Tv real old like around ten years?Watches alots daily like 6 or 7 hrs a day?The tv CRT-(tv tube) might be to old,the radiation colors guns R,G,B insisde might not work as well as before.Have a reset setting in the colors setting?Go down to that press that,to restting for the factory colors setting.Or tries add more blue,a bit less green and red,see how that turn out?
Panasonic... | Answered on Feb 05, 2011
You will have to resolder the vertical IC and in most cases replace any capacitor that is near and next to the vertical IC. There may be three capacitors that will be replaced, And while you are in the process of reworking the board inspect for any and all grounds that may need resoldered. You will have to look very close to find these. And you should search the deflection side of the board for two capacitors that have a 160 volt to 250 volts at 1MF, or 2.2 mf or 4.7Mf. By now these little guys are weak and need replaced. Thanks for asking and show a few hands of support!
Panasonic... | Answered on Jan 27, 2011
This is a function of your set-top box (STB), and has nothing to do with the TV. I know several FiOS users with the same trouble, and it's annoying but there isn't anything you can do to "fix" it. What is really strange is that the screen size can change even on the same channel, depending on the particular program being broadcast. It has to do with the aspect ratio of the programming from the provider.
Panasonic... | Answered on Jan 12, 2011
check for cold solder joints on power board around the relays
Panasonic... | Answered on Aug 13, 2010
while on press power and action buttons together for about 5 sec. that chk means you are in service man mode.
Panasonic... | Answered on May 25, 2010
upon realizing that no one would give me any suggestions without charging me, I solved the problem by lugging this huge TV out to the dumpster and throwing it in.
Panasonic... | Answered on Sep 11, 2009
A good eye could help you to know if a solder join is defective, get ahead lookin for it first. But the technical answer to know if the power supply shuts off because an over current or over voltage protection, is always a way to walk thrue. what is sure, it is, if you continue hitting the tv maybe is going to be broken totally.
Panasonic... | Answered on Apr 08, 2009
What you are calling the "antenna module" is actually the tuner. The connector that pulled out is called the F connector. The F connector can be soldered back onto the tuner but this is a very delicate procedure and is especially difficult if any of the coils in the area of the F connector have been bent, altered or moved. The tuner itself is not too expensive and is much easier to replace than trying to replace the F connector, especially if you have never done one before. If you use this set with a cable box then simply connect AV cables from the cable box to the TV set the TV to VIDEO.
Panasonic... | Answered on Dec 23, 2008
I think maybe the G-board needs to be replaced. A TV shop will have to repair it. They normally start around $200.00
Panasonic... | Answered on Mar 01, 2008
In set up, cc on mute set to no overrides mute selection on your remote control so cc stays on.
Panasonic... | Answered on Sep 17, 2019
Hi Mohammad Hooshmand, indicates model of the Panasonic DVD you are commenting on, in order to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola Mohammad hooshmand, indica modelo del DVD Panasonic del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
Panasonic... | Answered on Sep 15, 2019
Plasma TVs do run hotter than LED TVs. I suggest placing your TV into power saving mode which should reduce the heat.
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Do you mean Directv app? You'll need an Amazon Firestick or equivalent and stream the app from a laptop or desktop computer. You'll need to be a subscriber to use the app.
Panasonic... | Answered on Sep 02, 2019
Panasonic CT-32G23 32" TV Logo
14 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
tv appears black screen
  • Televison & Video
