20 Most Recent Sony KDL-52EX701 52 in. LED TV Questions & Answers
3-blinks by the SONY TV error code indicates that there is an audio circuit problem, ether is a shorted audio amp IC on the main board, or the power supply that supply the power to the audio amp section is defective.
Sony KDL-52EX701... | Answered on Oct 30, 2017
do you get any lines down the screen at all if not then the screen driver board has gone they are easy to replace. but you will first need to find out what board you have by its part number there is alot of screen controller boards and you will need the same one that is installed on to the screen. as long as there is sound then that is the fault.
Sony KDL-52EX701... | Answered on Sep 16, 2013
The problem in most of the case are:
1. Interference from a defective fluorescent lamp at your room sending signals to the infrared receiver of the TV.
2. Defective infrared receiver itself that sending noisy control signals to the CPU.
3. Defective manual control withes it has leakage.
4. Water damaged control switch PC board.
Sony KDL... | Answered on Oct 30, 2017
Do a reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sony KDL... | Answered on Jun 29, 2017
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
Sony KDL... | Answered on Jun 09, 2017
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board....
Sony KDL... | Answered on Dec 13, 2016
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sony KDL... | Answered on Nov 18, 2016
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Sony KDL... | Answered on May 10, 2016
three times red light blink mean DC Alert which is related to system in internally & some time sound ic problum
Sony KDL... | Answered on May 08, 2016
The most common defect that causes a 5 blink error on this model is the T-Con board. This board is now discontinued. You might be able to find one on Ebay or Amazon. If the T-con board does not fix the issue, then your panel is defective and your TV will need to be replaced.
Sony KDL... | Answered on May 06, 2016
Fault to the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Sony KDL... | Answered on Sep 10, 2015
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Sony KDL... | Answered on Jun 28, 2015
Sony KDL... | Answered on Mar 17, 2015
Check the tv is not against a wall and the air vents are not clogged with fluff. A flat screen tv expensive to repair.
Sony KDL... | Answered on Dec 24, 2014
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Sony KDL... | Answered on Sep 14, 2014
Sony KDL-52EX701 52 in. LED TV Logo
7 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
KDL Sony
  • KDL Sony
Most Popular Question
won 39 t stay
  • Televison & Video
