Panasonic CT-27D12D 27" TV
Problems with Panasonic CT-27D12D 27" TV?
Ask our Experts
Tell us why
Share your Experience
Do you recommend the
Troubleshooting and Support
Solved Problems for Panasonic CT-27D12D 27" TV RSS Feed
Click here to get instant support from our best Experts!
View More Results for Panasonic CT-27D12D 27" TV
Questions and Unsolved Support Problems
Unsolved Problems for Panasonic CT-27D12D 27" TV RSS Feed
Answer
i cannot change the channel with the tv remote or the channel button on the tv itself
Answer
finger tight cable wire to my 52 " samsung and the cable jack broke right off at the base. (... (More)
Answer
tv only recognizes up to channel 13. I've tried to auto program & manual program up from 13 but... (More)
Answer
Can I still connect cable through the input 2 jacks to the cable box?
Answer
I have been trying to work on my nephews Panasonic CT-2??? tv it doesn't have a manual but it does... (More)
Answer
Our panasonic tv has a perfect picture but no sound I tried to get the audio through the speakers of... (More)
Answer
Picture is usually OK when first turned on, but after a time (varies from minutes to hour+) the... (More)
Find a Manual
Panasonic CT-27D12D 27" TV Manuals & Guides
WikiManual
(Post a New Chapter)
How to Repair a Remote Control
Don't put up with your faulty buttons on you Remote Control anymore! If some of the keys on your remote have stopped working or you have to push... by wikihow
Upload Manuals
Tips & How To Guides for the Panasonic CT-27D12D 27" TV
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
My Magnavox TV is showing a feature screen
Press the channel up and volume down buttons at the same time on the front of the tv until the set goes off. When you turn the set back on the feature... written by rusty_etech
Magnetized TV, Poor picture, blotches, discolored, target shaped image
If your set looks like the one pictured above it is likely magnetized and needs to be degaussed (or demagnetizing). All CRT type TV's are prone to... written by johnnydiode
Help FixYa, Help you and help others. Share your User maunals and...
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for... written by stoneheaded
DTV transition: Options for Those with Analog TVs
On Feb 18, US viewers with analog TVs will no longer receive free over-the-air programming. In other words, if you've got an older TV with rabbit ear... written by Lauren_FixYa
Removing parental lock on RCA and GE TV sets
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method... written by techman
repair job update
Update A number of people have commented that after changing the color wheel, their red and blue colors are reversed. This is a different color... written by sweet_rascal
repair job continued
7. Locate the color wheel cover. It?s got a small green circuit board on top of it with a black/blue wires connected to it. Remove that plug. Also,... written by sweet_rascal
Purchase a Color Wheel & The Repair Job
My television is model Samsung HLM4365WX and the color wheel part number for that is BP96-00250A. This color wheel is used in many, many Samsung... written by sweet_rascal
I need help with
near zipcode:
Please enter your zipcode
Search
Top Repair Providers for Panasonic CT-27D12D 27" TV
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Ratings for the
Find a Warranty
Specifications for Panasonic CT-27D12D 27" TV
Key Features
Diagonal Screen Size
27 Inch
Display Capabilities
Aspect Ratio
4:3
Image Quality
Invar Shadow Mask
Without Invar Shadow Mask
Velocity Scan Modulation
Without VSM
Comb Filter
Digital 3-Line
Audio Features
Audio Type
Virtual Surround
Technical Features
Sleep Timer
With Sleep Timer
Energy Star Compliant
Connectors
Headphone Jack
With Headphone Jack
Screen Text
Channel Labels
With Channel Labels
Closed Caption on Mute
With Closed Caption On Mute
Dimensions
Depth
21.4 In.
Height
23.4 in.
Width
26.2 in.
Weight
77 lb.
Panasonic Contact Information
Main support number800-211-PANA
Describe your problem:
Top Standard... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
