20 Most Recent Panasonic CT-32SX12 32" TV Questions & Answers
first thing to do is take the back off and look at the fuse if your lucky thats the problem so u can make a cheap repair
Panasonic... | Answered on Nov 23, 2010
take the back off the tv and inspect the glass fuse off the ac power cord, it will probably be black and open, this is a common problem, it blows because the degaussing circuit works too slow, the original fuse is an 6.3 amp fuse, you need to replace it with a 6.3 amp slow blow or a 7 or 8 amp fuse to keep it from blowing, if you put an original 6.3 amp fast blow fuse in it, it will work for a while, but will blow again someday.
Panasonic... | Answered on Sep 07, 2009
You have a Voltage regulation problem.
Panasonic... | Answered on Mar 15, 2009
Unplug the set, remove the back and follow the power cord onto the main board, where you will see a small glass fuse. Replace that fuse with a new GMA 6.3 amp fuse. I have seen many of those fuses in Panasonics "pop" for no apparent reason. If that does not fix it then replace the back and have the set serviced by an experienced tech.
Panasonic... | Answered on Dec 02, 2008
TV turns on but doesn't stay on goes in and out then blank screen. LED light stays on during the entire time your problem is called hunting you can check power supply of your tv .It common problem in Philips T.V. Thanks
Panasonic... | Answered on Jul 06, 2008
Sure, Why not? It is worth the effort. If the set is 'dead', it is the easiest to repair.Only 'tampered' sets pose problems. It could be a simple blown Fuse, or the Power Regulator IC. This should not cost you more than $100-150 as Technician charges + 15-20$ for spares. It could also be a defective Horizontal Outut Transistor and short cicuiterd FBT, (tho' it seems remote), but if yes, add another $100. definitely worth calling a professional techie
Panasonic... | Answered on Jun 27, 2008
If it is a glass crt then you need to have the set demagnatized with a demagnatizing coil. All tv shops have one. This is worth fixing and usually at the price of a service call.
Panasonic... | Answered on Mar 18, 2008
I'm looking for the same info... my CT-32sx12f is completely dead too. I was wondering if the IC regulator or the flyback is bad. Fuse is fine. Anyone have any wisdom or experience on these sets they can interject? Thanks!
Panasonic... | Answered on Sep 21, 2007
It worked fine yesterday. Sound on all channels. Sometimes the picture goes black on channel 6. We can get it back by going up one channel, then back to 6. it is due to cable signal ie weak. now there is no sound this is due to sound section 1 loose connect in sound section 2 speaker 3 problem in sound section some part must have failed.
Panasonic... | Answered on Sep 20, 2007
I would say it is in the power supply circuit. check the 145 v line I do not suspect the problem in the video section.The 145 volts feed to the flyback.
Panasonic... | Answered on Jun 11, 2007
try wwww.ptscorp.com they might be able to help you.replace the power supply of ypour tv it have a short with a diode or the regulator.if you cannot do it yourself take it to a tech.
Panasonic... | Answered on Mar 23, 2007
NEVER EVER replace a fuse and think that va fuse will blow all by itself. The fuses are there to protect the set from catching on fire incase theres a short inside the set. Now in some cases an intermittant short can work after you replace the fuse but if its burnt black or brownish, theres a short inside the set in one of the circuits. always use a 100 watt light bulb across a blown fuse if your not sure if there is a short. if there is, the light will absorb the short and glow bright. if there is no short the bulb will glow bright , then go down very dim. you could have a main power supply problem, such as shorted bridge rectifyers,shorted main b+ capacitor, Hot could be shorted, or the Vertical or audio output IC could be shorted
Panasonic... | Answered on Sep 07, 2006
whats the make and model of the remote your using?
Panasonic... | Answered on May 14, 2019
try 1234 or 0000
Panasonic CT-32SX12 32" TV Logo
Popular Tags
17 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
panasonic tru flad model ct 32sx12f
  • Televison & Video
