TV was working fine this morning. Turned it on this afternoon and no picture. Green power light...
(More)
TV was working fine this morning. Turned it on this afternoon and no picture. Green power light comes on and flashes. TV makes a faint rapid clicking noise that might repeat a few times.
pink dot in the middle of the screen about the size of a softball on shows up with light colors on...
(More)
pink dot in the middle of the screen about the size of a softball on shows up with light colors on the screen
TV has become dim and has become dimmer as time went by. Replaced lamp earlier this year when the...
(More)
TV has become dim and has become dimmer as time went by. Replaced lamp earlier this year when the factory lamp blew. Not sure what is causing the dimming.
I have a panasonic pt 44clx65 that has a purplr spot in the bottom left hand corner. I just replced...
(More)
I have a panasonic pt 44clx65 that has a purplr spot in the bottom left hand corner. I just replced the lamp yesterday but it's still there. What else can i check and how do I get the screen off to clean the mirrors inside?
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
Apparently the TVGOS (TV Guide On Screen) signal on CBS stations (since the 6/12 digital changeover) can cause the sound to be missing on those...
written by jmorganti
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
