20 Most Recent Toshiba Satellite L645D-S4036 Notebook Questions & Answers
you can set it to show in the taskbar from the control panel
Toshiba... | Answered on May 16, 2013
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.
Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Toshiba... | Answered on Jul 07, 2012
The reconition code must have been wiped out, that can only happen if the ultility is agressive, It is far safer to erase the hard drive through more conventional methods, once you block any data from being retrieved so does the product identification. The only thing you can try is set bios factory default, "long shot at best"
Toshiba... | Answered on Apr 12, 2012
Hi.
You can try cleaning the keyboard but the keyboard has to be removed first before you attempt to clean it. That hopefully will work, however please be aware that if the wine has gotten between the keyboard membrane then it could cause the keyboard to type other characters not assigned to them or others as well as their own when you reinstall the keyboard.
To clean the keyboard first we have to remove it. Turn the laptop off and close the lid, remove any AC power that's connected. Turn the laptop over and then take out the battery.
In the battery compartment remove the 2 screws holding the keyboard bezel down that are circled in the picture below. (the keyboard bezel is thin piece of plastic that runs the length of the laptop above the keyboard)
When the screws are removed turn the laptop back over, open the lid and carefully lift up the keyboard bezel and remove it from the laptop like in the picture below.
Next you have revmove the three screws securing the keyboard in place like in next picture.
Lift up the top side of the keyboard and rest it on the palm rest/touchpad. Be very careful as the keyboard is still connected to the motherboard like in this picture below.
Now you have to remove the keyboard. In order to remove the keyboard you'll have to unlock the connector and release the cable.
Look at the next picture and lift up the right side of the locking tab so it opens up at a 90 degree angle as shown and carefully pull away the ribbon cable
Lift the keyboard away from the laptop and then get a clean, warm, damp cloth and start to wipe the top of the keyboard. Don't try to remove the keys as you can damage the cradles and also they are very hard to put back on.
Keep on rinsing the cloth with clean warm water and wring it out a bit. Keep on repeating this until the keys release and become springy again.
Once you are happy with keyboard just reinstall the keyboard by reversing the steps above.
When you have re-assembled the laptop turn it on and open a notepad or text document and see if the keyboard is typing all the correct characters for the printed symbol. If some are not working or are typing multiple characterst then you will need to replace the keyboard. Click on the blue link below for an idea.
http://shop.ebay.com/?_from=R40&_trksid=p5197.m570.l1313&_nkw=Toshiba+Satellite+L645+keyboard&_sacat=See-All-Categories&clk_rvr_id=242175125553
Hope this helps, good luck.
Toshiba... | Answered on Jun 20, 2011
If the lap top does not turn on with the power supply supply unit plugged in you may consider getting another power supply unit for your laptop. The computer should still turn on with the power supply unit plugged in if it does not then this has stopped working and needs to be replaced. From what I have read in your question that is what I would do. Thanks for using FixYa John
Toshiba... | Answered on Apr 13, 2011
Remove the battery and see if it starts up fine, if not then try the following:
1. Unplug your charger cord.
2. Remove the battery.
3. Press and hold the "Power" button for 30 seconds or longer
4. Now plug back in the power/charger cord.
5. Now put the battery back in.
6. See if it starts up now, laptops often get stuck in hibernate mode.
Toshiba... | Answered on Nov 13, 2018
Follow the procedure:
Device Manager
USB Root Hub (USB 3.0)
Change driver, manually, to "Generic SuperSpeed USB Hub"
Now the hardware is working
Upgrade the driver again, automatically
Toshiba... | Answered on Sep 25, 2018
  • The CMOS is, in basic terms, the part of the motherboard that stores the BIOS settings. To remove the BIOS password from your Toshiba laptop, your best option is to forcibly clear the CMOS.
    To clear the CMOS, you must remove the battery from your laptop and leave it out for at least 30 minutes to an hour. The way to remove the battery from your Toshiba will largely depend on the model. A common way to remove the battery--particularly with newer models--is to release the battery lock on the bottom of the laptop, while sliding the accompanying tab over to the side. This will pop the battery out from its tray so that you can then pull it out all of the way out.
    Before you remove the battery, turn off the laptop and remove the AC adapter. Otherwise, you could end up harming yourself or the laptop components. You must also ground yourself to prevent damaging the laptop with static electricity.
    After about a half an hour or more, return the battery back to its tray and lock it into place. Power on the laptop. The computericon1.png, ideally, should no longer ask you for a BIOS password.
    It's important to keep in mind that resetting the CMOS means that all of your BIOS settings will be reset to factory default. Also, sometimes you may need to leave out the battery for much longer than an hour to reset the password.
  • If resetting the CMOS doesn't work, then your next bet is to try using a backdoor password. A backdoor password is basically a password that manufacturers include with the BIOS so that technicians can access the computersicon1.png that people send in for repair. An example of a Toshiba backdoor password is, unsurprisingly, "Toshiba." When the BIOS prompts you to enter a password, entering "Toshiba" may allow you to access your PC and clear the old BIOS password. Another option is to hold the left "Shift" key down while booting.
Toshiba... | Answered on Sep 23, 2018
ok like all old laptops the CCFL lamps are now dead.
all are. if used every day and 20,000 hours hit, bam DEAD.
the CCFL are dead,
all LT made before 2010 had CCLF back lamps.(and monitors)
you hear the fan blow?, and no text on screen? (2 things)
your 14year old (today) the screen CCFL lamps are bad.
do this, 5 minute work. ok> and tell what fan does.?????
http://www.pcdied.com/monitors_and_screens/flash-light-trick.html
Toshiba... | Answered on Aug 26, 2018
How to Get Employment Security With Correct Japan Work Visa
Japan is no different from other developing nations whereby grass seems greener on its side of the pasture. It attracts its fair share of foreign businesses as well as nationals seeking to work within its lands. Albeit many adhere to immigration procedures, some choose to test their limits on the basis of ignorance or defiance. By understanding the different types of work visa in Japan, it assures its foreign workers a continual stream of income with no threat of arrest and deportation.
Visa simply infers the status of residence. Citizens obviously have no need of it as they automatically satisfy qualifications to freely reside in their country of birth. As for those of alien status who wish to join the local workforce, there should be a category to match one's requirement. Since most countries strive to improve the overall quality of life, professionals are generally welcomed to contribute knowledge and skill. Unskilled labor is normally not granted a visa to avoid flooding and dilution of the workforce.
The visa is awarded in accordance to one's area of expertise. Supported with proof of relevant experience, it is based on the field of involvement whilst working in the country. In the event one's work scope changes from one expertise to another, it is essential to apply for a visa under the new circumstances. Different types of work visa in Japan also apply to foreign companies seeking to conduct local business. Domestic companies based abroad wishing to set up a local point of presence need to provide supporting documents to justify internal transfer of foreign workers. Governmental staff for diplomatic duties is assigned a category for legal residence.
Over and above the general groupings, designated activities also garner approval from the authorities. Domestic service for non-native residents and citizens of certain nations on working holidays fall into this category of working visa. This, by no means, is the end of the list as it is best to consult the authorities on which visa serves best.
Click Here For More Details: http://japanjobandvisaservice.com/blog/change-your-luck-when-apply-work-visa
Toshiba... | Answered on Jun 05, 2018
gmail works of the speed of your connection if your d-link is faulty it will course connection problems try another router or connect straight to your modem [if your on cable] if adsl try doing a speedtest first.
Toshiba... | Answered on May 05, 2018
You need to set your bios power management.
Press F2 after pushing the power button then find power management and set disable for a wake up with any keys
Toshiba... | Answered on Mar 17, 2018
Backlights turn on automatically when you power on the computer. If you have no image on the screen, either the lcd inverter or screen is bad.
Toshiba... | Answered on Mar 09, 2018
I doubt a Windows 8 driver will work in your case. I would use Windows 7 or 10. You may need to use a USB graphics adapter in place of the internal. Many USB video adapters are more useful for that sort of thing.
Toshiba... | Answered on Mar 02, 2018
Toshiba Satellite L645D-S4036 Notebook Logo
16 questions posted
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
change hdd bios settings toshiba
  • Computers & Internet
