Panasonic DMR-E500HS DVD Recorder
Problems with Panasonic DMR-E500HS DVD Recorder?
Ask our Experts
Tell us why
Share your Experience
Do you recommend the
Problems
& Solutions
Manuals
& Guides
Repair
Service
Top
Experts
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Panasonic DMR-E500HS DVD Recorder RSS Feed
Click here to get instant support from our best Experts!
View More Results for Panasonic DMR-E500HS DVD Recorder
Find a Manual
Panasonic DMR-E500HS DVD Recorder Manuals & Guides
Tips & Tricks
(Post a New Tip)
My player does not read disks
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will... written by ginko
Factory Reset
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down... written by xmarine2847
Help FixYa, Help you and help others. Share your User maunals and service...
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the... written by stoneheaded
Having trouble recording TV broadcast to DVD?
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then... written by MateusDIY
Owners Manuals
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems... written by stoneheaded
Dish Network DVD Remote Codes
DVD Codes BRAND COMBO CODE Aiwa DVD 634, 694, 751 Alpine DVD 653 ... written by stoneheaded
if the disc tray doesnt open then follow these tips
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you can open the disc tray now 4)if there are any dust particles or... written by dileep007
Cleaning your cds or dvd discs
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if... written by BobbyR1234
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Top Repair Providers for DMR-E500HS DVD Recorder
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Featured Listing
Find an Expert
Meet our 4682 DVD Player Experts
budmrtn
#1: budmrtn
Rank: GuruGuru
Televisions & Videos ExpertExpert
Rating:  88%, 151 votes
Solutions:  744 (726 Votes in the last 30 days)
Experience: 30 Years of professional repair and design.
projdoc
#2: projdoc
Rank: GuruGuru
Rating:  94%, 611 votes
Solutions:  1205 (473 Votes in the last 30 days)
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
dmftrucker
Rank: GuruGuru
Rating:  87%, 412 votes
Solutions:  1582 (409 Votes in the last 30 days)
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
cene765
#4: cene765
Rank: GuruGuru
Rating:  89%, 401 votes
Solutions:  761 (387 Votes in the last 30 days)
Experience: More than 5 years attempt with printers, computers and all office equipment
Chu3505
#5: Chu3505
Rank: GuruGuru
Rating:  85%, 415 votes
Solutions:  1360 (386 Votes in the last 30 days)
Experience: I was an engineer for 20 years.I repair tv all models for 15 years for friend shop,was my hobbies.
k24674
#6: k24674
Rank: GuruGuru
Rating:  87%, 676 votes
Solutions:  1630 (355 Votes in the last 30 days)
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
justaskjoe
Rank: GuruGuru
Rating:  85%, 2016 votes
Solutions:  3902 (353 Votes in the last 30 days)
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Nomodo4u
#8: Nomodo4u
Rank: GuruGuru
Rating:  90%, 262 votes
Solutions:  480 (334 Votes in the last 30 days)
Experience: By using this stuff I know what I know when I know, but sometimes don't know how I know you know??
localwonder
Rank: GuruGuru
Rating:  92%, 2799 votes
Solutions:  4947 (316 Votes in the last 30 days)
Experience: I have yrs of experience dealing with many situations.
57 varieties
Rank: GuruGuru
Rating:  88%, 527 votes
Solutions:  1495 (273 Votes in the last 30 days)
Experience: I have been solving problems and fixing things for over 30 years!
Find a Warranty
Specifications for Panasonic DMR-E500HS DVD Recorder
Key Features
TV Tuner
Yes
DVD Type
DVD Recorder
Number of Discs
Progressive Scan
With Progressive Scan
Playable Disk Types
DVD-RAM · CD-RW · CD-R · CD (Audio) · DVD Audio · VCD · Picture CD · DVD Video · DVD-R
Playable File Formats
TIFF · JPEG · MP3 · MPEG4 · MPEG2
Video
TV Resolutions
480p (525p) · 480i (525i)
Picture Control
Brightness · Zoom · Contrast · Sharpness · Saturation · Black Level · Gamma Correction
Video Output System
NTSC
Video DAC
10 bit / 54 MHz
Video Noise Reduction
Block Noise Reduction · Mosquito Noise Reduction · 3D Noise Reduction · 3D Y/C Separation
Audio
Surround Sound
Dolby Digital (Digital out only) · Virtual Surround · Built-In DTS Decoder
Audio DAC
24 bit / 96 kHz
Dialog Enhancer
Yes
Connections
Outputs
Composite x 2, S-Video x 2, Component x 1, Analog Audio x 2, Analog Surround x 1, Digital Audio Optical x 1, RF x 1
Inputs
Analog Audio x 2 · RF (TV) x 1 · S-Video x 2 · Composite x 2 · iLINK DV Input
Front Panel
Composite Input · Audio Input · iLINK DV Input · S-Video Input
Convenience
Remote Control
Multibrand
Record And Play Fetaures
One Touch Recording · Simultaneous Record and Play · Playlist Playback · Time Slip · Chasing Playback
Instant Skip / Replay
60 sec. Skip
OSD
Yes: English, French, Spanish
Memory Card Slot
SD / MMC
Display Dimmer
Yes
Recorder
HDD Recording Time
89 Hrs. Minimum / 709 Hrs. Maximum
HDD Size
400 GB
Recordable Media
DVD-R · DVD-RAM
Programmable Timer
VCR Plus+
Recording Speeds
LP · SP · EP · XP · FR
Dubbing
HDD to DVD, 40x DVD Recording Speed
DVD Recording Time
1 Hrs. Minimum / 8 Hrs. Maximum
Recording Formats
MPEG2 · VBR Supported
Dimensions
Depth
11.94 in.
Height
3.13 in.
Width
16.94 in.
Weight
11 lb.
Other Features
Exterior Color
Silver
Warranty
Warranty
1 Year
Panasonic Contact Information
Main support number800-211-PANA
Describe your problem:
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
