tv was dead before... after I replaced the horizontal output transistor, a frying and tic-tic-tic...
(More)
tv was dead before... after I replaced the horizontal output transistor, a frying and tic-tic-tic sound is noticeable and arcing is visible at anode cap...after a few second it shut-off. no busted fuse was found but I can't get the power on again..i replaced horizontal output transistor again but still i can't get the power on., I checked the low voltage & B+ its okay.. i pull out flyback transformer and test at nearby electronic center--no short and open winding found... what are the possible fix for this problem?...need help.. thanks....
I purchased the Panasonic TV in Thailand and it has a differenct coax cable connector. Do you know...
(More)
I purchased the Panasonic TV in Thailand and it has a differenct coax cable connector. Do you know what type it is. It has no threads but the standard banana type plugs are to wide in the main pin.
I have a Panasonic TV/VCR/DVD, about five years old. My son was playing Playstation but now cannot...
(More)
I have a Panasonic TV/VCR/DVD, about five years old. My son was playing Playstation but now cannot get the TV off Line 2. When the remote was working I would hit the action button and go Line 1, Line 2, TV. I tried doing it on the TV itself via the channel button but only get Line 1 and Line 2. Any thoughts? Thank you.
Set performs perfectly upon power-up. Thin horizontal lines vibrate about 5 minutes after power-up....
(More)
Set performs perfectly upon power-up. Thin horizontal lines vibrate about 5 minutes after power-up. I am a novice but fully understand CRT discharge procedure B4 troubleshooting. Where should I investigate for this instability problem? Thanks for any help, Allan
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The web site for Broksonic: www.broksonic.com Tel: 800 333 9099 ( not sure where that is ) Trouble shooting, information on all products, and...
written by sandyjean
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
