20 Most Recent
Speed Digital Limited Quantum GoVault Data Protection Solution 3200 - Disk drive - GoVault - Hi-Speed USB - external - wit... 160 GB USB 2.0 Hard Drive Questions & Answers
How to read old quantum 100MB HDD
Does you motherboard have the old PATA connectors (white 4 pin molex power and 40/80 pin flat & wide data cables?
Being that old you may have to get the little jumper pins at the back to be set in the correct layout (probably slave).
You can also get external PATA cases or docking stations and set it up that way.
How to Clear Cache on Windows 10
There are several ways to help you clear your computer's cache:
Cleaning up the computer cache using a CCleaner
Clear temp files in settings
Using Disk Cleanup
Clear windows store cache
Clear browser cache
__Use CCleaner to clean up the computer cache__
To clear the cache on a Windows 10 computer, this is the easiest option.
CCleaner can do that, p you do and that is also with just two mouse clicks:
First of all, you should download and install CCleaner.
Start running CCleaner and click the option "analyze".
Click option Clean All.
This will delete the cache files on the Windows 10 computer.
My unisaw will not start. I tried to use it and it turned slow never getting up to speed and quit. now to does not do anything
Much depends on the motor type and how much internal and external protection it has - turning slow and then stopping does sound rather terminal especially if it made a laboured buzzing noise at the same time - but unless you have another motor waiting for a chance to be used it is best to take nothing for granted and check the circuit through with a suitable meter if the motor is receiving power it might just be there is a safety cutout that tripped because the internal centrifugal switch is seized, if the motor is that type...
What speed should I be getting with wifi
Hello, John -
Your WiFi speed depends upon your Internet service provider (ISP.) What speed did you contract for?
You can check your actual WiFi speed with the Ookla Speed Test (recommend by an AT&T U-verse technician):
http://www.speedtest.net/
If your actual WiFi speed is much less than what you are paying for, then contact your ISP and ask that a technician check the WiFi connection. Note: That may mean a technician will be scheduled to come to your home or place of business (wherever the WiFi connection is located) and you or someone else will need to be there. Plus, you will probably need to provide your customer account number and another form of ID when you call the ISP customer support number.
Best wishes.
I have an ADSL line but my line speed is only 3.15mbps and upload only 0.42?
See if it changes throughout the day depending on usage. Download speeds under 5Mbps are fairly normal. Your upload speed is usually one tenth the download speed which is consistent with what you are experiencing.
If your service provider indicated a higher download speed, check with them, they may have you on the wrong server or settings.
My computer download speed is slow even i have high speed fiber connection 200mbps
Goodday, this is difficult to analyze without further information: Did you change anything on your computer? How old is it?
Are you using Wifi or a cable? Be aware that download speeds also depend on the server on the other side, so even if you have the fastest fiber internet, downloads from a slow server may take more time.
Did you check your speed with a special program or website? Search for a speedtest online and try how fast your connection is.
200 mbps means that a 700 MB movie / CD image would take about 28 seconds to download.
Check the bits and Bytes converting about how fast your connections should be.
Good luck,
A.Misset
