Panasonic PV-C2061 20 in. TV/VCR Combo
Problems with Panasonic PV-C2061 20 in. TV/VCR Combo?
Troubleshooting and Support
Solved Problems for Panasonic PV-C2061 20 in. TV/VCR Combo RSS Feed Post a New Problem
Panasonic PV-C2061
I CANNOT GET TO THE MENU SCREEN DUE TO NOT HAVING A REMOTE. HOW CAN I GET TO THE MENU SCREEN
2 Solutions
remote cotrol does not work except in...
My remote control for PanasonicPV-m2023 does not work except in close range. I have replaced new Batteries too? can you...
1 Solution
manual code to program remove for...
I need the manual code to program remove for panasonic pv m2023.Thanks
1 Solution
Channel/clock auto set
My TV is not hooked up to cable, I just play video games on it. When I turn it on, it says  CHANNEL/CLOCK AUTO SET...
1 Solution
TV/VCR PV-M2023-R or PU-M2023-R 1995
My Tv/VCR &remote wont hold channel programing and must be reset each time the machine is turned on. It will only...
1 Solution
Loss of color - all green
The tv/vcr works great but the color is all green. Can this be repaired?
1 Solution
Panasonic PV-C2061 Part ID
I have two smoked components that I can't identify. Would anyone be able to help id the following? Panasonic model...
2 Solutions
Unsolved Support Problems
Unsolved Problems for Panasonic PV-C2061 20 in. TV/VCR Combo RSS Feed Post a New Problem
Black square
I have a black square taking up most ove the TV screen... how do I get rid of the black square taking up most of the...
Post a Solution
Channel/Clock auto set
ok my tv isnt connected to cabel cause the adapter is broken is there a way to fix it so i can play video games on AUX...
Post a Solution
panasonic pv m2023
the menue option wont work on my remote and i can not find a menu option on the actual tv to run the auto program its...
Post a Solution
On/Off doesn't work anymore
The remote stopped operating the "on/off" function first but it would work manually. Now it doesn't turn on at...
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
TypeTV/VCR
Screen Size20 inch
Number of Video Heads4
Panasonic Contact Information
Main support number800-211-PANA
Sponsored Links
Loading problems.
Top Experts
Ask Me
bobbyj Guru
2 solutions
Ask Me
likha Wiz
1 solutions
Ask Me
jango2 Wiz
1 solutions
Repair Service
Find TV Combo Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
