FixYa.com
Panasonic PT-56TW53 56 in. Rear Projection Television
All Products > Panasonic > Projection Televisions
Problems with Panasonic PT-56TW53 56 in. Rear Projection Television?
Troubleshooting and Support
Solved Problems for Panasonic PT-56TW53 56 in. Rear Projection Television RSS Feed Post a New Problem
No Audio or Video, blinking power light
Hi, All of a sudden, I came out of another room to find the picture gone and the power light blinking 3 times, then...
1 Solution
removing kft7aa334f1
How do I remove cables from kft7aa334f1; there is 1 thick red cable and 1 thin red cable, keeping my board attached. Is...
1 Solution
Blue convergence way off
the tv has been fine until we moved. Then one day the blue is way off, and arcing in the corners and edges.No luck...
2 Solutions
double images
Green converge seems to be way off. Worked fine last night Unable to adj. Also pic is bent inward on right side.
1 Solution
pt 56tw53 picture trouble
television went off by itself. power but keeps flashing. i unplugged the set for about 1 hour. it turned on but the...
1 Solution
problem with picture
I was given a panasonic pt-56t53w projection TV.We figured out how to do the convergence for the colors, but I still...
1 Solution
RED STREAKS ON BOTTOM 1/3 OF SCREEN
MY HDTV PROJECTION MONITOR DISPLAYS RED STREAKS ON BOTTOM 1/3 OF SCREEN. I HAVE ATTEMPTED THE CONVERGENCE PROCESS TO NO...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Panasonic PT-56TW53 56 in. Rear Projection Television RSS Feed Post a New Problem
TV will not come on
TV will not come on - power indicator light blinks red
Post a Solution
panasonic pt-56tw53 56
Was watching regular TV channel an TV became distorted, read manuel tried to converge, the green color seem to be bent...
Post a Solution
No image...Just Blue, Red and Green lines.
I had a tech look at my 3.5 year old Panasonic and wants 580 to fix the Sweep Circuit. What does that mean? Is it worth...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Screen Size56 inch
Display Capabilities
Aspect Ratio16:9
Remote Control
Remote ControlUniversal
Image Quality
Velocity Scan ModulationWith VSM
Comb Filter3DYC / 3D Digital
Adjustable Color Temp.With Adjustable Color Temperature
Audio Features
Audio OutputVariable / Fixed
Audio TypeSurround
Sound LevelerWith Audio Leveler
MTS StereoSAP / MTS Stereo
Secondary Audio Programming (SAP)With SAP
Technical Features
Picture in PictureWith PIP
Sleep TimerWith Sleep Timer
Energy Star CompliantEnergy Star Compliant
Screen Text
Channel LabelsWith Channel Labels
Dimensions
Depth24.8 in.
Height57.5 in.
Width59.5 in.
Weight252 lb.
Panasonic Contact Information
Main support number800-211-PANA
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
