Panasonic PT-51G44 51 in. Rear Projection Television
Problems with Panasonic PT-51G44 51 in. Rear Projection...?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Panasonic PT-51G44 51 in. Rear...
Troubleshooting and Support
Solved Problems for Panasonic PT-51G44 51 in. Rear Projection Television RSS Feed
View More Results for Panasonic PT-51G44 51 in. Rear Projection Television
Questions and Unsolved Support Problems
Unsolved Problems for Panasonic PT-51G44 51 in. Rear Projection Television RSS Feed
Answer
I have a pt53wx42f rear projection tv and the picture is starting to go dark especially noticed when... (More)
Answer
holographic image or double image especially when red colors are showing.
Answer
I have a pt51g63w panasonic rear projection tv and the blue bulb is out of alinement and leaves a... (More)
Answer
t.v. makes a pop noise then the screen gets fuzzy,if I go up to the t.v. and hit the side the screen... (More)
Answer
After Hurricane Ike and the power black outs, my TV began turning itself off. This only happens... (More)
Answer
When the screen gets brighter it zooms in and the picture has become dark most of the time. The... (More)
Find a Manual
Panasonic PT-51G44 51 in. Rear Projection Television Manuals & Guides
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
Tips & How To Guides for the Panasonic PT-51G44 51 in. Rear Projection...
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
Mitsubishi Green Blinking light of death
This information applies to Mitsubishi sets that have a Model number beginning with VS, WS, WT etc. It does not apply to the WD series of sets made... written by SD Tech
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W..,...
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W.., D61W.. · Symptom: No Convergence, Picture is bowed and distorted,... written by johnnydiode
Samsung Color Wheel replacement!
This varies a little depending on model number of the set. Usually a bad color wheel will produce a high pitched sound or even a grinding noise; some... written by SD Tech
Sony KP51hw40 etc with Blue screen and or Shuts down
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Panasonic PT-51G44 51 in. Rear Projection Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Ratings for the
Find a Warranty
Specifications for Panasonic PT-51G44 51 in. Rear Projection Television
Key Features
Screen Size
51 inch
Audio Features
Sound Leveler
With Audio Leveler
MTS Stereo
SAP / MTS Stereo
Secondary Audio Programming (SAP)
With SAP
Technical Features
Parental Control
Without Parental Control
Connectors
Headphone Jack
Without Headphone Jack
Panasonic Contact Information
Main support number800-211-PANA
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
