The tv is greenish colored for a while before it goes back to normal color. It can be 5 to 30...
(More)
The tv is greenish colored for a while before it goes back to normal color. It can be 5 to 30 minutes before it goes back to normal.
My Panasonic PT-53TW54 will not turn on. I hit the on button it clicks like normal and then like 10...
(More)
My Panasonic PT-53TW54 will not turn on. I hit the on button it clicks like normal and then like 10 seconds later clicks again. Then the power light blinks once then a pause then 1 blink and so on. Any insight would be helpfull please.
My Panasonic PT 53TW54J has a green half circle or arc from the left to right side bottom of the...
(More)
My Panasonic PT 53TW54J has a green half circle or arc from the left to right side bottom of the screen. Converge adjustments will not fix it. I am an electronic tech so if someone tells me what part to replace (part #) I can replace it myself. I have done some research and a similar description of a problem for a different make says to replace the two IC's (STK392-110) and it will fix the problem for that make. I called a repairman who is telling me it will cost over $400 to fix. I'm just not going to pay that to fix it.
My PT-53TW54 is about 3 years old and has all of a sudden changed all images to a zoomed in state....
(More)
My PT-53TW54 is about 3 years old and has all of a sudden changed all images to a zoomed in state. Whether I am watching normal broadcast tv or a movie on my Bose DVD system, the same problem still exists ... regardless of what picture aspect I am in. It also appears that the left and right side of the screen are blurry and convergence is out a bit even though the center looks fine. Any suggestions?
I am trying to connect my laptop to my tv and I can't find the correct cable or in what seting to do...
(More)
I am trying to connect my laptop to my tv and I can't find the correct cable or in what seting to do it.
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
I received a full refund for this tv, Monday Oct 6, 2008. Thomson had a courier pick up this tv at my home 2 weeks ago. Just call the numbers I have...
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
