20 Most Recent Panasonic PT-56HX41 56" Rear Projection Television Questions & Answers
0answers
2answers
No picture or sound on Toshiba 53HX71 Rear Projection TV
Gm pagbigyan mo naman ako nga pokemon
12/23/2014 11:00:33 AM • Panasonic... • Answered on Dec 23, 2014
Panasonic PT-56HX41 - I have
The three blinks is indicating that the convergence circuit has failed and shut the set down. You can get the convergence repair kit for your model from www.tvrepairworld.com which has the Parts and the CD with instructions for the repair
8/6/2011 11:53:48 PM • Panasonic... • Answered on Aug 06, 2011
Turn on power hear it
Blinking light may be a error code----look closely and see if blinks in a sequence---3 blinks, pause 3 blinks or 5,5.
The blinking light means set is in protective shutdown, Do you see a sequence to the blinks?
I am here to help.
If needed, unplug set and plug it back in and try to turn on---watch for likely error code.
SD TECH
9/17/2010 11:11:34 PM • Panasonic... • Answered on Sep 17, 2010
Color shadowing
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
7/3/2010 6:50:52 AM • Panasonic... • Answered on Jul 03, 2010
Won't fire up. LED light blinks 3 times, pauses
Three blinks is a common symptom of a convergence short circuit. If you goto www.TvRepairKits.com look for their convergence kits for you model. They have put together kits that include OEM parts and step by step photo instrucitons.
6/6/2010 4:34:08 AM • Panasonic... • Answered on Jun 06, 2010
2answers
Where can i find the
encompassparts.com has the parts listed, but this unit is too old to get most parts vaguely through online
you could check out tvrepairman.com
to find an authorized panasonic repair center that may be able to fix the problem with the TV
4/29/2010 12:18:39 AM • Panasonic... • Answered on Apr 29, 2010
Projector
if this piece of glass is in the image pathway you require the correct replacement part to install and that are quite sizable and expensive
4/29/2010 12:15:38 AM • Panasonic... • Answered on Apr 29, 2010
Panasonic Cinemavision PT-56hx41e, wording on screen is red?
the convergence circuit governing the red picture has gone defective and needs attention possibly a convergence amplifier IC or and convergence coil at the red CRT went defective
4/29/2010 12:12:24 AM • Panasonic... • Answered on Apr 29, 2010
My panasonic pt-56hx41 tv will not turn on. All it
projection TV`s have integrated protection circuits
built into the circuit design, these circuits turn the
power off automatically when a fault has bin detected this
is in order to prevent a more costly repair, these circuits monitor
power supply , vertical and horizontal deflection
over voltage, or x ray, and also faults with convergence circuits.
Diagnosing these faults require test equipment and a good knowledge of
electronic repair techniques, and also a repair manual.
4/29/2010 12:04:31 AM • Panasonic... • Answered on Apr 29, 2010
Panasonic (PT-56HX41PF) rear-projection tv with no picture
The three blinks indicates a convergence IC fault. The convergence ICs must be replaced with the manufacturer replacement part. Use only the original replacement part. Your set uses STK392-110 convergence ICs.
These ICs are mounted on a large heat sink. Yes, you can replace it yourself and save few hundred bucks. But you must be knowledgeable enough on how to solder, resolder and use a multimeter.
You will need:
  1. Convergence ICs
  2. Heat sink grease or thermal compound
  3. Soldering iron
  4. Solder lead.
  5. Digital multimeter
  6. Solder pump
  7. Small side cutter
Feel free to inform me if you decide to replace the ICs yourself
12/4/2009 3:10:02 AM • Panasonic... • Answered on Dec 04, 2009
2answers
Panasonic blue convergence problem
Yea, you have to have the two convergence Amp IC's replaced. Should run you about 300 bucks or so. Good Luck
5/7/2009 2:30:43 PM • Panasonic... • Answered on May 07, 2009
2answers
Panasonic hd projection with conver. problems
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
3/26/2009 5:35:06 AM • Panasonic... • Answered on Mar 26, 2009
PANASONIC PT47WX54J
If you do not remember your code, LOCK will unlock in
12, 24, or 48 hours, depending on the current set-up. Be
cautious when selecting ALWAYS. If ALWAYS is
selected and you forget your secret code, the TV must
be serviced by a qualified technician to clear the LOCK
set-up.
• If you select CHANGE CODE, and you change your
code from the one used in the LOCK menu, your new
code becomes the controlling code.
2/12/2009 1:03:26 AM • Panasonic... • Answered on Feb 12, 2009
No sound and the power light is blinking
I had similar issue with power light blinking 3 times and no audio/video.
The problem was a burnt resistor and gone convergence ICs. I replaced both ICs (safer bet unless you know exactly which IC covers what guns in your specific TV) and the burnt resistor by myself and the TV looks good as new.
1/16/2009 5:53:11 AM • Panasonic... • Answered on Jan 16, 2009
I need to find the outside screen mine broke
Good day mate
Could you please give me actual screen details in centi meter I have got a few Panasonic screen
please reply for this mail or our Email adress [email protected] .nz
thanks Som
12/21/2008 8:01:59 PM • Panasonic... • Answered on Dec 21, 2008
Interested in an older model panasonic
You can not buy a extended plan. I would pay no more than 500.00 for a excellent condition and picture quality.
11/18/2008 1:34:57 PM • Panasonic... • Answered on Nov 18, 2008
Green out of alignment
Yes the amps are most likly the problem. I would let a repair shop do this because you need to adjust the geometry for the green. It can be hard to do this.
11/18/2008 12:02:09 AM • Panasonic... • Answered on Nov 18, 2008
Panasonic PT-56HX41 56" Rear Projection Television Logo
Popular Tags
35 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
panasonic pt 56hx41
  • Televison & Video
