I am unable to remove the thinner red wire that is connected to tall tower to the far right of the...
(More)
I am unable to remove the thinner red wire that is connected to tall tower to the far right of the circuit board. It is a Panasonic PT-47WX42F RPTV. I am replacing the STK392-110 chips because the blue convergence is off and cannot be adjusted by remote. I am just wondering if there is a trick to getting this wire out. There is a thicker red wire connected to the same area. That one came out easily by pushing it in and twisting and pulling it out. They appear to be the same type of wire, but the push and twist method is not working with this wire. Is there a different technique to get it out?
when you watch a scroll going across the bottom it starts out fine but as it travels across the...
(More)
when you watch a scroll going across the bottom it starts out fine but as it travels across the screen it seems to be going downhill
I replaced the lamp assembly and the machine still states that it need a replacement lamp and now it...
(More)
I replaced the lamp assembly and the machine still states that it need a replacement lamp and now it will turn off at the drop of a hat. What the heck is up with this machine.
When I try to power up the red led turns on for about 2 seconds, turns off and then starts blinking...
(More)
When I try to power up the red led turns on for about 2 seconds, turns off and then starts blinking 5 times then repeats.
The television has no picture or sound and blinks at intervals with red light when power is turned...
(More)
The television has no picture or sound and blinks at intervals with red light when power is turned on. It is noted to make a squealing noise of some type with initial power turn on
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
I received a full refund for this tv, Monday Oct 6, 2008. Thomson had a courier pick up this tv at my home 2 weeks ago. Just call the numbers I have...
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
