Panasonic PT-50LCX64 50 in. Rear Projection HDTV Television
Problems with Panasonic PT-50LCX64 50 in. Rear Projection HDTV...?
Ask our Experts
Tell us why
Share your Experience
Do you recommend the
Panasonic PT-50LCX64 50 in. Rear...
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Panasonic PT-50LCX64 50 in. Rear Projection HDTV Television RSS Feed
View More Results for Panasonic PT-50LCX64 50 in. Rear Projection HDTV Television
Questions and Unsolved Support Problems
Unsolved Problems for Panasonic PT-50LCX64 50 in. Rear Projection HDTV Television RSS Feed
Answer
I have a Panasonic PT-50LCX64 that is 2 1/2 years old. When I turn it on it has a green screen--no... (More)
Answer
it just shuts off and blinks every so often but is happening more and more also when there is a... (More)
Answer
A blue screen come on the tv and say," airfilter need cleaning" how is this filter... (More)
Find a Manual
Panasonic PT-50LCX64 50 in. Rear Projection HDTV Television Manuals & Guides
Tips & Tricks
(Post a New Tip)
Mitsubishi Green Blinking light of death
This information applies to Mitsubishi sets that have a Model number beginning with VS, WS, WT etc. It does not apply to the WD series of sets made... written by SD Tech
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W..,...
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W.., D61W.. · Symptom: No Convergence, Picture is bowed and distorted,... written by johnnydiode
Samsung Color Wheel replacement!
This varies a little depending on model number of the set. Usually a bad color wheel will produce a high pitched sound or even a grinding... written by SD Tech
Sony KP51hw40 etc with Blue screen and or Shuts down
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now... written by SD Tech
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Panasonic PT-50LCX64 50 in. Rear Projection HDTV Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Featured Listing
Rate and Review the Panasonic PT-50LCX64 50 in. Rear Projection HDTV Television
Write a review:
Rate this product:
Would you recommend the PT-50LCX64 50 in. Rear Projection HDTV Television to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for Panasonic PT-50LCX64 50 in. Rear Projection HDTV Television
Key Features
Screen Size
50 inch
Display Format
1080i (HDTV) · 480p (EDTV) · 720p (HDTV)
Digital TV Standard
HDTV
Projector Technology
LCD
Display Capabilities
Aspect Ratio
16:9 · 4:3 Enhanced
Built-in Tuner
NTSC · ATSC
Remote Control
Remote Control
Standard
Illuminated Remote
Illuminated
Image Quality
Comb Filter
3DYC / 3D Digital
Audio Features
Audio Type
Surround
Sound Leveler
With Audio Leveler
MTS Stereo
SAP / MTS Stereo
Secondary Audio Programming (SAP)
With SAP
Surround Sound Type
Dolby Digital / AC3
Technical Features
Picture in Picture
With PIP
Parental Control
V-Chip
Sleep Timer
With Sleep Timer
Connectors
Rear Input Connectors
Audio (Mini Jack) x 1 · S-Video x 2 · Audio (RCA) x 2 · Composite x 2 · 1 x D-Sub (RGB PC)
Front Input Connectors
Composite x 1 · Audio (RCA) x 1 · S-Video x 1 · D-Sub (RGB PC) x 1
Screen Text
OSD Languages
English · French · Spanish
Closed Caption on Mute
With Closed Caption On Mute
Speakers
Number of Speakers
4 Speakers
Dimensions
Depth
15.3 in.
Height
35.3 in.
Width
55.7 in.
Weight
85 lb.
Panasonic Contact Information
Main support number800-211-PANA
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
